Applying fairing compound to frames before planking
Discussion in 'Wooden Boat Building and Restoration' started by lftmx3, Jun 10, 2015.
  1. lftmx3
    lftmx3 New Member
    I have a few slight (@1/32-1/16") low spots when i put a straight edge on the bottom. Being a racing runabout I know its important to be very flat. Is it permissible to add compound on the lows in just a few areas? Seems like there would still be plenty of bare wood for the ply/epoxy bond.
  2. keysdisease
    keysdisease Senior Member
    I would use thickened epoxy, not fairing compound. Fairing compound may crack and break out under load, I would think you want to use something structural and not cosmetic
    :cool:
  3. gonzo
    Likes: 2,367, Points: 123, Legacy Rep: 2031
    You could used thickened epoxy and let the plywood float when you glue it.
  4. PAR
    Scab in a piece of the same species of framing material and plane/hone it down to the desired dimensions.
  5. michael pierzga
    michael pierzga Senior Member
    Yah...use the same material as the frame for filling substantian gaps.
    If the gap is small high density filler will work fine.
  6. peterjoki
    Likes: 4, Points: 8, Legacy Rep: 14
    peterjoki Junior Member
    As Gonzo wrote.
    Or glue thin strips/veneers of wood to the frames, and fair again. I prefer this approach as it is 100% certain to eliminate any chance of a poor glue up.
