Anyone here ever mount a electric trolling motor in a kayak
Discussion in 'DIY Marinizing' started by dock83, May 26, 2010.
  1. dock83
    dock83 Junior Member
    Anyone here ever mount a electric trolling motor in a kayak I mean on board?
  2. rmenasco
    rmenasco Junior Member
    Do you mean built-in? Or just a mount for one?
  3. dock83
    I ment on board. Not too hard I dont Think? And would work great with a simular steering system too a jet ski. Rather than a rudder.
  4. rmenasco
    There is already a company out there in the us that makes kayaks with built in motors... I'll find the site and post the link for you
  5. rmenasco
    One of the sites is.... www.kayacht.com. this is one of the sites, but it is not the site I was talking about. google search electric kayaks and you will find several companies that make them.
  6. dock83
    Thanks I'll check it out.
  7. rmenasco
  8. dock83
    Thanks forthe info but I'm looking for a DIY Job I will Try it one of these days. TIME IS THE FACTOR.
  9. pistnbroke
    Likes: 35, Points: 48, Legacy Rep: 404
    pistnbroke I try
    depends on what the kyak is made of but the simplest is to pass a tube say 1 inch dia through the hull glass or whaterver to suit hull material and then fit the trolling motor with the prop at the bottom and the control handle at the top...some dismantling required to pass it through the tube and a good fit would be best ...for speed some g clamps and some wood
  10. dock83
    Thats what I was thinking But my hull is pastic but I can work with that. What are G Clamps?
  11. pistnbroke
    pistnbroke I try
    if its a plastic hull with a deck I think a plastic tube through the two would be best the bottom hole needs to be a very tight fit so perhaps a tapered hole if the plastic is thick enough and some silicone on the inside ..Only problem with mounting the motor under the canoe is that you increase water depth required and you carnt get it off easily.....g clamps try the hardware tool shop
  12. dock83
    I was thinking plastic welding the tube through the plastic as for the weight I dont realy care but finding a platic tube with the same chemical make up as the boat my be fun. As for the motor I wnt too mount it in the boat not under it.
  13. FAST FRED
    FAST FRED Senior Member
    There is zero reason to mount the system inboard.
    An electric trolling motor mounted to a back rest will do just fine , you could offset the battery a couple of inches to make up for the weight.
    The tiny thrust of the unit will never cause problems , and if time is a concern , there is no faster way.
    Cost almost nothing , risk, Zero!
    Good motoring,
    FF
  14. tinkz
    Likes: 2, Points: 0, Legacy Rep: 23
    tinkz New Member
    yes-n-no to that, kinda..
    what I'd done is slap together a simple 1 sheeter:
    http://koti.kapsi.fi/hvartial/oss2/oss2.htm
    did the main cuts at 26-11-11 instead of the 28-10-10 specified and gained a good inch when I put gunwales onto it.
    as a "kayak", paddling with kayak paddle, it swung left-right kinda wild and had a tendency to spin out with any good speed, the waterline only being about 5.5-6' worth because of the inclined ends, oh well.
    on the plus side, it carried myself and 2 kids on the pond for a ride, was 170+100+65 lbs total was kinda impressive, so I didnt want to just torch it.
    1 sheet luan, 1 12' 2x4, a little glue, effort, and paint.. not a big deal.
    I cut a hole into it and boxed in a motorwell for a little 30# MK. trimmed the MK's shaft down about 9" worth was about right for it. the tiller was right where I wanted/needed it to be sitting about centered.
    the blind was just painted window screen mesh and arrow shaft blanks, it rolled up into a nice little bundle, a little crude, but was plenty effective.
    not knockin anything, but why butcher a good plastic kayak?
      File size:
      25.4 KB
      File size:
      17.9 KB
  15. whitepointer23
    if you want to fit a tube for the motor you could buy a 1 inch skin fitting and fit that to the hull, watertight and all you need is your drill, then you get get a piece of pipe with a 1 inch socket, screw it on with some thread tape and your done, the parts would cost bugger all and it would take 1/2 an hour.
