Any pics of DynaRig or Maltese Falcon stowing its sails inside mast?
Discussion in 'Sailboats' started by Squidly-Diddly, Dec 20, 2011.
  1. Squidly-Diddly
    Likes: 168, Points: 63, Legacy Rep: 304
    Squidly-Diddly Senior Member
    Any pics of diagrams of it "in the act" so to speak?
    Are there just big rollers inside the cross-masts?
    I can't even find a pic of sails half deployed.
    I thought I heard the sails were stowed inside the vertical masts, but that doesn't seem right.
    this has close up, but of what I'm not sure
    http://www.waddiloveyachts.com/maltesefalcon.pdf
  2. Doug Lord
    Likes: 348, Points: 93, Legacy Rep: 1362
    Doug Lord Flight Ready
  3. Angélique
    Likes: 335, Points: 83, Legacy Rep: 1632
    Yachting World: Three Winged Falcon . . . .
    From Doug's link . . .
    Cheers,
    Angel
  4. Angélique
  5. Squidly-Diddly
    THX, I get it.so the sail is sucked into the vertical mast from the sail's center?
    Because I'm seeing solid panels with maybe some stitched joining in the middle.
    I guess that would make sense because it would be hard to roll it up inside the curved DynaRig cross-masts(what is correct term).
    ANY pics of the sails in 1/2 deployed state?
    I would think THAT trick would be heavily promoted by the maker and owner.
    Right up there with those "hard top convertibles" with about 7 separate panels and god knows how many little servo-motors, pulleys and tracks.
  6. Angélique
    Maltese Falcon » Furling the sails
    ‘‘ wind on the beam, furls her sails into her carbon-fiber mast ’’
    Cheers,
    Angel
  7. Angélique
    I think so too, but too bad last pic is from aft, otherwise we'd be sure....
    Yards I think.
    Cheers,
    Angel
    PS - a sail pops out of the mast at the start of the vid in post #4
  8. Angélique
    At 2 min 28 sec in the vid . . . . the top sails are coming out . . . . as triangles . . . . bottom of the sails first . . . . . moving to the outside along the yards . . . . .
    Cheers,
    Angel
    P.S.
    The sails are coming out of the mast with ± their final side form, so the top sails must be coming out as triangles on top of the 2th to top yard, as the top yards are shorter . . . . . For the bottom sails the coming out triangles must be pointed down from the 2th to bottom yard as the bottom sails have a shorter yard at their bottom.
  9. brian eiland
    Likes: 213, Points: 73, Legacy Rep: 1903
    brian eiland Senior Member
    You might have a look at the first portions of this video
    http://www.youtube.com/watch?feature=endscreen&NR=1&v=KZoS93qkZHw
