Janis_59
Junior Member
- Joined
- Aug 30, 2022
- Messages
- 14
- Reaction score
- Location
- Riga, Latvia, European Union
Hi! Hopefully I will not lift the already discussed theme(dead corpse kicking), but searcher shows not much of this was ever touched. So, I have 29 ft sailboat from about 1980+ when in Europe was no regulations about earthening of mast. Mast is 25x15 cm 11 m aluminum. As the last year I got in the violent not forcasted thunderstorm where flashing occurs each 2 seconds so near as 50 meters off to me, I am scared now. Thus I see the mast-top earthened spike is mandatory. But - that is exactly the point where the VHF antenna stays. Antenna has mandatory rule be no nearer than 0.94 meters off the ANY metallic parts (wavelength half). But the platform size is 25x15 and no more. How should I mount the peek? What have to be taller than antenna having 457 mm height. Should I construct some sort of side-keeper thus the two rods are scraping the sky, where antenna in center and thunder thing is meter aside, higher? Seems illogical and fancy. Or construct the antenna be inclinable or some sort of hinge, downward and upward, thus the thunder peek is only some 20 cm upper the mast top? Or use the antenna spike as streamer sharpness spitting charges against flash? But cable, in-spite it is rather heavy, have only 2 mm of central diameter, thus it is too small against existing recommendations. Or let I lower the antenna? Then the reach will be lost and then mast electronic shade will make a partial short-circuit to antenna field. That not good idea as well. So, what I should do before lift up that mast now??
