anti-slip finish
Discussion in 'Fiberglass and Composite Boat Building' started by kane_new, Nov 11, 2010.
  1. kane_new
    kane_new Junior Member
    hi does anyone know anything about putting something into the deck mold before the gel coat (like a cloth) to create an anti-slip surface instead of painting anti-slip after the deck is removed from the mold
  2. susho
    Likes: 6, Points: 8, Legacy Rep: 78
    susho Composite builder
    paint it on the plug ;) then build your mould.
  3. gonzo
    Yes, you mold whatever texture you want. It is the way almost every boat is built. Take a walk to the closest marina and look. They make rolls of material that you glue to the plug.
  4. War Whoop
    Likes: 16, Points: 0, Legacy Rep: 84
    War Whoop Senior Member
    For a mold yet to be built? or an existing mold ,New tooling nonskid ,http://www.gibcoflexmold.com/ They sell both sides the male can be used for repair work.
  5. Landlubber
    Landlubber Senior Member
    In China, have a yap to the DIAB fellas in Shanghai, they will tell you where to get it from.
  6. kane_new
    its an existing mold, does anyone know the proper name for it and a link to a website which sells it
  7. Landlubber
    ...DIAB fellas in Shanghai
  8. kane_new
    sorry landlubber totally skipped over your first post thank you very much, very helpful
  9. Landlubber
  10. mark775
    mark775 Guest
    Wow - What an impressive bunch of textures! They sure do look pretty, too. Lubber, do any actually work as a nonskid or, like every I've seen, are probably worse than no texture - particularly after a miniscule amount of wear.
  1. container
  2. Tom Mckinney
  3. andy47
  4. midcap
  5. pierreuw
  6. flyineagle
  7. bashley
  8. simon
  9. vincent9993
  10. lausl
