Anti Capsize / Damage and Sails
Discussion in 'Multihulls' started by Fanie, Dec 8, 2007.
  1. Fanie
    Fanie Fanie
    I see there are members, junior members and senior members, but no big or small members :D Probably a good thing ;)
    Mr Mercedes Beanz, you have to take into consideration that any and all protective and preventative gimmics in vehicles will of course be pushed to the limit by someonem and the same would happen in a boat.
    Nice avatar, do you know who it is :D
  2. oldsailor7
    oldsailor7 Senior Member
    I think Meanz Beanz post # 102 says it all. :cool:
    Only on a slippery racing cat ---more so. :eek:
  3. Fanie
    Fanie Fanie
    The idea of the sheet release is not to compensate for neglegence or unattendance of the controls. The idea was to, when a squal that would otherwise cause damage to a rig, release the sail just before the point where the sails will get ripped off, torn, or a mast broken.
    I don't have the same sailing experience you guys have, but there seem to be some occasions where stuff gets buggered up by the sudden impact of a wind. I've read some articles, in some, sails were ripped up and some had broken masts. Maybe they were old boats with rotten wooden masts or expired sails.
    If you guys tell me it's not something to worry about, it happens very seldom, then it probably won't be worth the effort to make one. If squal damage is a frequent occurence then it should be considered.
  4. Manie B
    Likes: 123, Points: 63, Legacy Rep: 1818
    Manie B Senior Member
    Nice to read the old thread again
    thanks guys
    this is what originally sent me in the direction of the gaff rig for my cat one day
    for one i dont have to turn the boat into the wind to lower the main
  5. Meanz Beanz
    Likes: 33, Points: 0, Legacy Rep: 585
    Meanz Beanz Boom Doom Gloom Boom
    Hey Fannie, did you know that the introduction of ABS dramatically increased the number of roll over accidents?
  6. masalai
    masalai masalai
    Manie, did you know that another man died as a result of being hit by a boom - don't use mainsails.... with boom -
    Similar thing applies to "releasing cleats" as applies to self lifting rudder blades - prone to happen at the WRONG time -
    A sacrificial rudder blade - at least will allow you to continue for a while without ripping the whole rudder assembly off.
    Correspond with Bob Oram, he has a system that seems to be workable and the sacrifice is a half inch dowel that should break and is easily replaceable...
  7. Fanie
    Fanie Fanie
    I guess you have to weigh it up against the amount of accidents it prevents on a daily basis in the first place. If the ABS proved to be a disaster instead of a solution they wouldn't use it any more. You can take your's out if you want to :D
  8. Meanz Beanz
    It ain't that simple... car sales and insurance are two different things, the insurances companies just adjusted premiums to cater for the differing damage (less accidents but much worse). All the car companies have done is pile on extra tech to compensate for it, things like ESP's, side air bags etc.... I wonder what will happen as we drive to the limit of the new tech?
    Anyway it illustrates the law of unintended consequences, **** happens even with a well researched well executed product.... :D
  9. RHough
    Likes: 61, Points: 0, Legacy Rep: 793
    RHough Retro Dude
    I just skimmed through 8 pages of this.
    To all those that made comments that gimmicks are no substitute for good seamanship. +1
    To all those that think it is possible to have a gust or sudden squall catch a boat by surprise and the gimmick would be a safety feature, you are not good seamen and no number of gimmicks are going to help. -1
    If you know your boat and are constantly aware of conditions, you never have enough sail up unattended for it to be a problem, you never leave the sails unattended when conditions are threatening or unstable, or you reduce sail and speed so that you can safely leave the sails unattended for a period of time. Until you know what conditions are threatening, you should maybe man the sheets until you do.
    Flame away. :)
  10. yipster
    Likes: 98, Points: 58, Legacy Rep: 1148
    yipster designer
    no plus nor minus point for me i guess, still, i dare say, the computer and robots will take over :p
