stonebreaker
Senior Member
- Joined
- May 23, 2006
- Messages
- 438
- Reaction score
- 12
- Location
- Shiloh, IL
A ton of feathers or a ton of lead... so near, and yet so far...
Note: This feature may not be available in some browsers.
stay the same, its that same as taking a pee in the bath tub the water level will stay the same,, and before you say something iam a showerman
Some folks need to read more carefully and reconsider. The water level will change if there is a change in displacement; now then, is there a change in displacement?What happens to the water level relative to the lock sides?
A steel ship loaded with iron ingots and continuously fully borne on water is moved into a lock and the gates of the lock are closed. No water can come in or go out of the lock.
The crew takes all the iron ingots and throws them into the water in the lock.
Well it works in practice... but will it work in theory..?
