An odd question about corcell foam
Discussion in 'Materials' started by Tungsten, Jan 22, 2022.
  1. Tungsten
    Tungsten Senior Member
    Good day, I need some help with a project.
    I have some left over foam, A 1200 corcell Id like to use it for a planter box.
    My question is can bare foam be used, is it safe? The foam will always have moist soil on it.
    Weird question I know, thanks.
  2. fallguy
    Likes: 1,986, Points: 123, Legacy Rep: 10
    I don't believe it will be very stable in sunlight. I doubt very much it would work without some paint that has uv inhibitors.
    DogCavalry likes this.
  3. Tungsten
    Yes thanks, I should have said its for the bottom of a SIP container. Sub irrigated planter. So no sunlight will hit it.
  4. fallguy
    It won't do well with shovels or even hand tools hitting it. But for personal use; you'd understand its weakness there. Otherwise a layer of glass would toughen it up a lot
  5. Tungsten
    My question is more about the foam being safe for roots as these are editable plants,anything to be worried about as far a chemicals leeching etc.
    Googling Styrene acrylonitrile just spins me in circles lol.
    Well, wikipedia has a good blurb.
    It is considered food safe for containers, but long term studies showed that acrylonite can migrate and is carcinogous. Not sure I got the verbage correct.
    I'd be inclined to find something inert to place inside it, or change the soils every season..
  7. Tungsten
    Perhaps a coat of epoxy over may help?
    How long would I have to wait for the epoxy to fully cure?
  8. Tungsten
    It’s one of those deals you know I’ve had this piece laying around my garage for years. Finally find a use for it since it’s fairly strong at 12mm thick. I’ve cut it already to fit. It’s about 24”x 15”.
  9. fallguy
    Epoxy would work most likely. If san core eats epoxy; we are all in trouble with our epoxy boats.
    Just 24 hours is enough. It'll finish curing over next 7 days long before anything else happens.
    Tungsten likes this.
