AMC 258 six cylinder
Discussion in 'DIY Marinizing' started by alanrockwood, Apr 3, 2011.
  1. alanrockwood
    Likes: 17, Points: 18, Legacy Rep: 116
    alanrockwood Senior Member
    Just out of curiosity. Is the AMC 258 cubic inch straight six a good engine for marinizing? I understand it is considered one of the better straight six auto engines.
    Likes: 1,490, Points: 123, Legacy Rep: 2031
    No, unless you want an expensive hobby and are really qualified to re-engineer it.
  3. alanrockwood
    Good point.
    I'm just curious though.
  4. CDK
    CDK retired engineer
    I think you are talking about the engine from an AMC Pacer.
    It was notorious for the long exhaust manifold that used to break in the middle after a few years because of contraction/expansion. AMC never solved that problem, the replacement manifold also broke.
  5. alanrockwood
    The engine was manufactured for many years, both before and after the Pacer line of carr was made, and even after AMC itself disappeared. It was a fairly popular and well regarded engine in the Jeep product line and continued to be manufactured up until relatively few years ago.
    I don't know if it had the problems you noted in all its incarnations, or just in the Pacer line.
  6. CDK
    My experience is limited to two Pacers I owned many years ago. One used gasoline, the other one I converted to LPG; both suffered from the manifold issue (among lots of other problems as well).
  7. PAR
    Likes: 496, Points: 93, Legacy Rep: 3967
    Nothing a header wouldn't fix. The 232 AMC engine was the one you wanted, not the 258. The 232 was a solid engine, produced for a long time and I think a left over casting from Nash (could be wrong here). As far as a marine conversion, if you have one hanging out of you pocket, then use it, but there are much more common L-6 engines to choose from, making parts reasonable.
  8. alanrockwood
    The 232 AMC engine was introduced after the Nash era was over. It came out in 1964. Variants of this family came in a variety of displacement ratings and the family was produced until 2006.
    Possibly the 242 cubic inch version may be better than the 258 cubic inch version I first mentioned. The 242 was the one produced until 2006.
    The biggest member of the family was 282 cubic inches.
  9. alanrockwood
    If not the AMC straight six, then what are some other good straight six engines for marinizing?
  10. alanrockwood
    Thanks for the replies so far.
    Now that I think about it, I think the topic is a better match to the DIY marinizing discussion group. Would it be possible to have the thread moved over there?
    Thanks.
  11. Boat Design Net Moderator
    Likes: 143, Points: 43, Legacy Rep: 1004
    <thread moved to DIY Marinizing>
