amateur wingmast
Discussion in 'Multihulls' started by luftspringaren, Jul 16, 2008.
  1. luftspringaren
    luftspringaren New Member
    I am thinking about building a carbon rotating wingmast, does anyone have any hints on simple amateur DIY methods to use?
    Do I really have to build a female mold or are there other ways?
    I will have to get an expert to calculate the structures of course. :)
    Luftis
  2. Petros
    Likes: 139, Points: 63, Legacy Rep: 1593
    Petros Senior Member
    There are a couple of ways to do this without a mold: one is to build it like you would a strip hull construction, with little cedar strips, in two halfs and glue together. Another is to use a hot wire cut foam core. You can even solvent-melt the foam out of the mast shell when done. If you seach the archives there are links site with pictures of these methods.
  3. rob denney
    Likes: 84, Points: 28, Legacy Rep: 436
    rob denney Senior Member
    G'day,
    I sell plans and materials for building a carbon/foam wing mast (stayed or unstayed) with integral sail track and all required fittings that does not require a mould.
    Depending on the detail required, our engineer will calculate the scantlings for about $800.
    regards,
    Rob
    www.harryproa.com
  4. Jimbo1490
    Likes: 41, Points: 28, Legacy Rep: 527
    Jimbo1490 Senior Member
    These guys have the coolest materials for making masts; braided and unidirectional carbon sleeve.
    http://www.braider.com/index_lo.html
    If your mast is on the long (tall?) side, you'll need to carefully select the resin system and curing schedule to avoid problems.
    Jimbo
  5. Doug Halsey
    Likes: 104, Points: 53, Legacy Rep: 160
    Doug Halsey Senior Member
    Gary Baigent briefly discusses how be built a wingmast in the following thread: Boat Design Forums > Design > Multihulls
    Hydrofoil Trimarans in New Zealand : Attn Gary Baigent
    (See the last post, to date)
  6. waltm
    waltm Junior Member
    There was a post on catsailor about building strip plank / carbon masts a while ago and a build log. Might be worth a look.
    Building a mast
