Scot McPherson
Senior Member
- Joined
- Jan 11, 2017
- Messages
- 103
- Reaction score
- Location
- New England
chebacco is popular
Note: This feature may not be available in some browsers.
Youŕe mistaken. Vikings had master builders who were also naval architects/engineers with an enormous experience. Very empiric, the bad designs and or poorly built boats would eliminate by themselves sinking and drowning the crew. The builder would be eliminated by different means as hanging or beheading. That should be applied to bankers nowadays, and the financial system will improve..Build and enjoy. Just use common sense. Remember there were no naval architects building for the Vikings, just smart carpenters who studied out the problems. Ask questions and welcome to the forum!
For some time now I've maintained that some "professions" just do not have a decent claim for respecting their "credentials" given that it is difficult, sometimes even impossible, to test the soundness of their decisions and proposals until long after they've been gone, at which point it's often too late and the damage is done.The builder would be eliminated by different means as hanging or beheading. That should be applied to bankers nowadays, and the financial system will improve.
This is the blue moon I built, ( first Try at boat building) admittedly the cabin is pretty square but I think it looks OK with the porthole & sliding cabin top.
Thanks.Rurudyne, your post above; what an excellent and concise summing up of some professionals.
Are you familiar with Oliver Wendell Holmes Sr.'s poem,There are plenty of well founded designs that are likely to provide exactly what you're looking for, just needing some aesthetic upgrades to suit your whims. Designing a 20' sailboat isn't a great feat, though you sure can build an ill handling beast if you don't know what you're doing. Most of these older designs can be converted to taped seam or other build type, with some education or help. Pick up the book "Elements of Boat Strength" to get a handle on some of these conversion processes and a general idea of what might be involved with your self designing a fresh new boat.
Find a design that is close and make the appropriate modifications, so it suits your needs. Try to avoid reshaping the hull other than a 10% - 15% straight stretch (if desired) and you'll probably float upright come launch day. Screw with the hull shapes and rig balance very much and you might have extreme difficulty, trying to quantify any changes and modifications, to address issues (there's always issues).
Lastly, yes there sure is such a thing as overly or too strong. A perfectly engineered structure will suddenly, explode when it reaches its failure point. This means all the elements of the structure were sized appropriately for their loads, no heavier than necessary and contributing equally to the whole. If an element is "too" strong, it will transmit higher loading to less substantial surrounding elements, forcing them to tolerate more than they can take and now you have an often difficult to diagnose, localized failure.
No, what is scary is when a professional tells an amateur that they need to correct something to prevent loss of life, and the amateur thinks that they know better. Really, anyone can build as boat, and I will venture to say that 75% of boats built and used are built by people who do not have "school recognized" ability. That's OK. What really irks me is when someone comes to this forum looking for approval and doesn't find it, then begins to disparage those who have gone through all the classes. Physics doesn't care if you think you are correct.When a total amateur attempts to design a boat (say, a sailboat < 20 feet), or a tiny houseboat/shantyboat -- a box, basically, on a scow hull or pontoons), is that an insult to professional naval architects and yacht designers who have been properly educated/schooled/apprenticed, etc.?
