Dear all
I am working on a 30 m aluminum catamaran project and I did all necessary calculation for determining the scantling for the cross beam in terms of strength.
In my thought, This portion will consist of upper plate (which is the main deck) and lower plate and there are stiffeners welded on both plates. (it look like double bottom on other words)
In my design I am including some deck transverse with 2.5 m spacing which will be needed to be welded in both upper and lower plates, but I am not sure how it will be welded to the lower plate since this place will be closed and not easy accessible. same thing if I have center girder which go in the vessel center line.
My 1st question is, should I include these deep deck transverse and center girder in my design ?
Second question, what is the proper height for the cross beam measured from main deck downward to make it accessible for welding ?
dose anyone have a sample plan of catamaran cross section to have idea about how this cross beam is reinforced ?
and please let me know if I misunderstand something.
