Yes definitely you need more details I updated my post as following with some pictures from which you can have amps and speed welding parameters:
test result:
6mm thickness - 300 mm long butt joint:
Radiography test – which passes without porosity., sometimes small porosity shows.
Bending test – no cracks observed – result satisfactory
Tensile test – min required 305 Mpa – Result obtained 280 to 285 Mpa
Failure at welded Area. (at moment failed testing piece not sent back from test lab!)
We use 99,9% Argon gas, 1,2 mm ER5183 filler alloy wire (best suitable imported from USA), we use Aceton cleaner before
60 degree beveling sanding (30 degree on both sides)and within 3 minutes welding from bottom "upwards" (standing pieces) .
Key factors, believe, are suitable heat and speed?!
Can you send the picture of the back side of the weld bead sample?
