Aluminium Boat Interior Construction
Discussion in 'Boat Design' started by sequent, Jun 18, 2006.
  1. sequent
    sequent New Member
    Hi all,
    Sorry if this is a stupid question, but I'm trying to find out how, for example, carpet or material and/or wood panelling and linings, as well as cabinets are fixed to the cabin sides, specifically in the case of aluminium boats? Are they glued-in, screwed-in, or is some other methodology used? I basically want to know the process to go from a bare alloy hull and cabin to the finished interior.
    Any advice would be appreciated.
    Dave.
    There can be a variety of methods. It depends on the materials you are using, if they are structural members, design characteristics, etc.
  3. sequent
    sequent New Member
    Are there any good references (books, links etc) you could recommend where information about the various methods can be found?
  4. SolomonGrundy
    Likes: 9, Points: 18, Legacy Rep: 51
    SolomonGrundy I'm not crazy...
    There are a number of resources available such as: Boatbuilding with Aluminum by S. Pollard, Colvin's book Steel Boatbuilding is worth looking at too, even if your boat won't be steel.
    A common method of installing interior joinery is to weld "tabs" of either bar stock or an extrusion (angle) and just screw into the tabs.
  5. Lyle Creffield
    Lyle Creffield Junior Member
    Hi
    i believe that welding angle say 50x50x8 and self tappers (screws) to fix ply would be the simplest interior fit out
  6. FAST FRED
    FAST FRED Senior Member
    To make an aluminum cruising boat more habitable many are foamed inside , insulates temp & noise.
    Unfortunatly most spray foam is REALLY FLAMABLE so a "Cieling" (a full interior lining) is a requirement .
    You will need to weld the tabs on before spraying the foam.
    FAST FRED
  7. Lyle Creffield
    Fixings-internal
    Hi
    i do appoligise
    i am thinking 10mm alloy hull so as to weld direct to hull
    lyle
