Air pressure regulator diaphragm
Discussion in 'Outboards' started by rovi, Apr 23, 2016.
  1. rovi
    rovi Junior Member
    Hi all, has anyone ever replaced the diaphragm in an air pressure regulator on the optimax? I'm trying to replace a ruptured one but there's a heavy spring that's creating some problems. I can't get to insert the four small bolts because of the tension on the spring, what should I try? Thanks
  2. Mr Efficiency
    Follow workshop manual's instructions.
  3. rovi
    rovi Junior Member
    I'm not seeing that kind of info anywhere, maybe that procedure is elementary, hence it's not documented. I can probably use a clamp or small spring compressor but there are two very small holes in the housing and I am not certain of the way those should be positioned.
