Air-Only Ventilators - A question. Perhaps someone in Europe knows.
Discussion in 'Fiberglass and Composite Boat Building' started by missinginaction, Mar 6, 2026.
  1. missinginaction
    Likes: 266, Points: 83, Legacy Rep: 512
    missinginaction Senior Member
    I don't post too often here anymore. But back between 2007 and 2016 or so, this site was responsible in large part for a restoration that I did on a 1973 Silverton Sedan. I did the grunt work but I could write for hours about all the help and encouragement that so many provided. I'll post a photo of my boat and below ask a question.
    When I built the boat I decided not to add a hatch to the foredeck. After running the boat for a dozen years I'm still OK without a hatch. But I'm doing some long distance traveling now and would like to add some ventilation to the cabin. So I've been looking at vents and dorade boxes.
    I came across a company in Europe. In Ukraine. Air-Only Ventilators seems to have an interesting approach. I'm wondering if anyone has any opinions on their products.
    Air-Only deck ventilators – for yachts, workboats, liveboats and other small ships https://air-onlyventilators.com
    Thank you in advance for anything you can share.
    Best Regards,
    Missinginaction
    (Bart)
  2. DogCavalry
    Likes: 1,821, Points: 113
    DogCavalry Senior Member
    Well, it looks pretty good. But I have never used one.
    missinginaction likes this.
  3. jehardiman
    Likes: 1,510, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    I've never seen one used either, but they look a lot like an "improved" Nicro Fico/Marinco low profile vent. It is important to note that both of those vents were powered. Given the flow complexity and float restrictions of the Air-Only vents I would expect them to need forced intake/exhaust also.
  4. missinginaction
    Thanks for the replies guys. Jehardiman, Air-Only does offer a powered ventilation fan as an option. Below is a link to their product line. The fan option will flow about 50 cubic meters per hour and has a couple of speeds according to air only. It's using a small computer fan, only draws about 0.12 amps @ 12 volts. I'm just trying to find out if anyone has actually used one of these and how they liked it. I'm fishin for some opinions.
    Products – Air-Only deck ventilators https://air-onlyventilators.com/products/
    MIA
  5. wet feet
    Likes: 635, Points: 113, Legacy Rep: 124
    wet feet Senior Member
  6. baeckmo
    Likes: 905, Points: 113, Legacy Rep: 1165
    baeckmo Hydrodynamics
    Have used the Air-Only type with good results; has quite low internal losses, so works fine without fan, yet efficiently blocking water entrance. The Vetus model not good enough in exposed positions, like MIA's fore-deck.
  7. missinginaction
    Thanks for the feedback baeckmo. That was just what I was looking for. I appreciate you taking the time!
  8. missinginaction
    I received the air-only ventilator from Ukraine on April 1st. I ordered a couple of the low profile vents with the optional fans. Items came well packaged and were undamaged in shipping. Ordering process was straight forward. A little different than ordering from an internet retailer in the United States but I had no issues. There was a one week delay in getting confirmation on the order. After that the communications was fine. I ordered the item on March 1st, so it took exactly a month for them to get it here.
    Maybe this information will be useful for someone considering using an air-only product.
    Thanks to everyone who weighed in on this.
    MIA
    1. Limulus
    2. Portabletelly
    3. Roy Senior
    4. iaff284
    5. mrG
    6. Jason Rodgers
    7. Jason Rodgers
    8. Steve_uk
    9. Boom Up Bob
    10. Diyguy.
