Again gelcoats, forever and ever
Discussion in 'Fiberglass and Composite Boat Building' started by oneilmemo, Sep 2, 2008.
  1. oneilmemo
    oneilmemo New Member
    To be honest i know nothing about boats but i have been assigned to make an extensive research about gelcoats and that is why i am here. i have a few questions and need some verifications. i hope someone will help me:
    - i have been assigned to represent gelcoats within an absolute and general formula that will be valid for all-purpose gelcoats. so i divide gelcoats into 3 subtopics 1. base-resin type 2. additives 3. inhibitors/catalysts. resin types are listed and limited as epoxy (especially), unsaturated polyester, vinylester, thermosetting acrylate and phenolic. i divide additives as fillers (there are lots of fillers), pigments, thixotropes, suppressants, UV inhibitors, fire retardants and conductive agents. i found only one inhibitor or catalyst or accelerator which is MKEP (if you know more please tell me). If there is nothing wrong up to here i want to ask my questions:
    - Since gelcoats are derived from one of the resins above, the gelcoat will exhibit ALL the mechanical and physical properties of THAT resin whatever the additives or inhibitors added. Is that right? If so, what happens if i try to utilize from two or more combinations of resins as base resin?
    - and the additives.. Do they make any chemical reaction with polymer bonds so that change their chemical properties or are they (resin+additive+inhibitors) together just a homogeneous mixture in which both resin and the additive exhibit their properties separately?
    - as you know each type of resin type i listed above are also divided into subtopics say epoxy has bisphenol, novalak bla bla types or uns. polyester has orto- iso- etc. types. Can i make such a generalization: all types of say again epoxy resins can be used in forming gelcoats? Is there any restriction for resins to form gelcoat?
    - one more question.. for example i have a raw composite material which has polyester resin that is reinforced by say glass fibers. Can i use any gelcoat that has any type of base-resin? Is it like blood type conflict or any gelcoat type can be applied to any composite material?
    - finally (i hope so) is there any possible application of gelcoats during or after any process regarding composite materials (like filament winding or vacuum infusion etc.)
    For now that's all. Thank you all already.
  2. the1much
    Likes: 44, Points: 0, Legacy Rep: 696
    the1much hippie dreams
    hahhhaaahahaha,,,,,,, sorry dude,,, you just made me not want to EVER gel-coat again. hehe :D
  3. oneilmemo
    it is an honour for me to make you laugh. i wish you could share this honour with me dude and try to make me laugh by helping?
  4. the1much
    ill make ya laugh by telling you ,," to me, theres a big difference in knowing all there is chemically with gel,,,, and being able to use it the right way."i can do any kind of gel work,, have done it for years ,, but NEVER have i read a label,, or want to know all the complications of each gel, what each is made from, what each chemical does,,,,,all that stuff is "book learning",, which is WAY different then "piratical learning"
    MEKP,, is the only cat. that i know of.
    mixing resins "together" i cant imagine would do any good,,, only bad.
    and if you mix gel, additives, cat.,,, they MUST bond together,, or NONE of them would work,,, it would be like oil and water,, they would always separate.
    and mixing resins work if you do it the right way,,,,,,example,, epoxy will bond to poly,,, BUT,, poly wont bond to epoxy.
    im sorry dude,,, i aint got NO "book smarts",, im just a simple "pee-on" ehhe ;)
  5. oneilmemo
    You're rigth they are all book stuff and i hate that way too. But as i said this is an extensive research and i have to complete in one week i guess by writing a report :S. and to me, i am just a trainee with nothing but google cause there is no speciality of any book in our library on gelcoats. But i can say we are both laughing now. Thanks dude.by the way could you give more examples like epoxy gelcoat can be applied on polyester based composite but poly wont bond to epoxy as you gave above? i will be gratefull if you mention all the possible combination you can give with a little scientific reason.
  6. the1much
    epoxy will mechanically bond to poly,, and a little chemical bond. poly will only mechanically bond to itself after the first coat is 24 hours old,, before the 24 it will chemically bond. vinyl will mechanically bond to poly,,, and to itself(after 24) before that,, it will only mechanically bond to poly, and chem. to itself. but NETHER of these will bond to epoxy. but epoxy will bond to them the same as to the poly.
    im not an
    "epoxy dude" i've used it on small parts and small applications,,, ive built 1 boat with it,,,but these guys on here have taught me alot.
    you should search for member " Par" ,, him and a few others know a WHOLE lot more then me on this "book smarts" hehe ;)
    again dude,,,, im sorry i cant be alot of help,,,, i dont think i have EVER written a report in my life,,haha,,, and the only books i "read" are the ones with lots of pics of nekkid women,,haha :D
  7. tinhorn
    Likes: 20, Points: 18, Legacy Rep: 310
    tinhorn Senior Member
    Well, maybe I can add to the1much's Dearth of Knowledge.
    I divide gelcoats into 3 subtopics 1. base-resin type 2. additives 3. inhibitors/catalysts.
    I've used polyester and vinyl ester gelcoats. Thermoset acrylate and phenolic MAY be those plastic sheets that are formed in a mold, then fiberglass applied to the sheet. They're not gelcoats, but have advantages of pretty patterns such as marble or granite. They're also for sissies who can't spray 18 mils in three passes.
    Vinyl ester gelcoats are said to not give as high a polish as polyester. When I was in the business, urethane gelcoats were available which were said to provide superior "shiny".
    Pigment is your color, of course. Thixotropes are what give the gelcoat the ability to hang on vertical surfaces (or upside-down). With no thixotrope, it would run off like syrup. UV inhibitors help keep the gelcoat from dulling in the sun. Fire retardants keep the gelcoat (and presumable the resin) from supporting combustion.
    I'm not surprised that MEKP is the only catalyst you find. That other one (whatever it's called) will cause discoloration.
    These are good questions for your gelcoat supplier.
    I've seen resin tinted with pigment for both open mold and resin transfer processes. After the part has been made, sure, you can spray it with gelcoat.
    My pleasure.
  8. juiceclark
    juiceclark Previous Member
    Excellent synopsis th.
    One can also take the ******* approach like me: I asked the dude who has owned the fiberglass supply company for 40 years which gelcoat to use on my project. Bought him lunch after he took an hour to visit my project and told him the picture of his wife in his wallet is real perdy!
    If my experience is any indication, not only will he suggest the perfect products for your project in great detail, but he'll sell them to you for the same price as that huge boatbuilder down the road. (he doesn't like them)
    You can never know everything in this or any business. There's just too much to know. Find smart people and make them your friends...it's your only hope.
  9. the1much
    well Thanky T.H.,,,, and J.C. ,,, man this dude makes me feel stupid,,hahahaa :D
  10. tinhorn
    Yup, that's my favorite. I used to have one awesome sales rep - an old dude who would get me samples of ANYthing. "Hey, tell me about this ceramic filler I read about." Poof - the guy brought me an entire bag. I asked about plastic microspheres and got a whole box. It was huge! Parabeam, graphite/kevlar weaves, whatever I was curious about trying, he'd bring me like a year's supply - free! And hell, I was operating out of my garage at the time!
    I asked him about it once. He said he treated little guys just like the big guys because his biggest accounts had also started in their garages.
  11. the1much
    hehe,,, wanna know why i ALWAYS ask em what i should use?,,,, so when its wrong THEY get charged for the re-do hehe :D:D;)
    i STILL do it with awl-grip.
    i think the "smart" people in the boating industry are the ones that cover their @sses !! hehe :D
  12. oneilmemo
    Thanks to all of you dudes, i am shocked rigth now, what a chat! i know this will shock you messieurs and i am terribly sorry but i still doubt about these questions:
    - and the additives.. Do they make any chemical reaction with polymer bonds so that change their chemical properties or are they (resin+additive+inhibitors) together just a homogeneous mixture (mechanical bonds only) in which both resin and the additive exhibit their PROPERTiES separately?
    - one more question.. for example i have a raw composite material which has polyester resin that is reinforced by say glass fibers. Can i use ANY gelcoat that has ANY type of base-resin? Is it like blood type conflict or any gelcoat type can be applied to any composite material that is to be gelcoated?
    by the way i wish i could be smart but i am just a prisoner of education.
    @ the1much
    these couplings about bonding of resins you did yesterday.. I recognize now cause i couldnt have read carefully due to running out of time and i am sorry my reply is quite late now. Anyway these couplings are really important to me; are they for mixing the resins for forming a base-resin of a gelcoat or did you mean epoxy gelcoat will chemically bond to a polyester composite material by saying that epoxy will bond to poly?
    - One more questions could you suggests a gelcoat formula for something like that:
    I have carbon fibers impregnated with epoxy resin just before filament winding. i want to make a motor case which has a inner surface that will resist to heat up to 200-250 celcius degree and i want the motor case not to leak the liquid fuel and could conduct electric current. what type of gelcoat you can suggest? this was my estimation (i made up whole the example) but they will ask me something like that so i just tried my chance.
  13. the1much
    1 -yes,,,,,,,,and you cant mix different types of resin together
    2- no ,, additives does not change chem. properties
    3- YES you can,, if done the way we explained before,,poly with onoy poly,,vinyl with vinyl or poly,, epoxy with all
    4- epoxy resin is epoxy no matter what ( gel,, glass resin) its in. them bonds go cross the board no matter what we're talking bout.
    last one--- NOPE ,, you wont find any gel to stand up to that heat,,, most "high temp" paints wont handle that heat.and NOPE you wont find any gel that holds up to fuel.an i have NO idea about conducting electric,,,, never tried it,,hehe ;)
  14. juiceclark
    Speaking of "high temp", I've seen two boats with dark blue hulls recently where the dark color obviously generated such temperatures as to further cure the fiberglass underneath. On one Grand Banks, the weave of the 2nd layer of glass was showing on the sides of the hull.
    The third boat I've seen this on is my own - from being painted flag blue awlgrip. That hull gets so hot in the sun it has further shrunken the glass. So, looking down the side of the boat you can barely see where the bulkheads are...like a starving dog.
    My point: you can become so technical with some stuff that the obvious can be overlooked - like the long term affects of your color additives.
  15. rwatson
    Likes: 495, Points: 83, Legacy Rep: 1749
    rwatson Senior Member
    JC - Just reading sam devlins book on boat building- he has a whole section on how dark colours can 'melt' the epoxy, and create the printhru.
    I would be surprised to hear that polyester or vynelester gets affected by heat, but I know that epoxy can be.
    Would these boats have used epoxy on them?
