Aftmast rigs???
Discussion in 'Sailboats' started by jdardozzi, May 28, 2002.
  1. CT249
    Likes: 266, Points: 83, Legacy Rep: 215
    CT249 Senior Member
    A fast craft can't afford to point low in terms of apparent wind, because its apparent wind is so far forward that if it points low it will just reach back and forth. It's the other way around - the faster a craft is, the more attention must be paid to reducing drag and creating a high-pointing rig and foils.
    This can be seen very dramatically on a high performance windsurfer or windfoiler, where you can easily switch entire rigs. If you use a rig or setup that "points off the wind" you will just reach back and forth, or maybe not even do that, because the apparent wind is so far forward. To get upwind you need a very high-pointing rig.
  2. brian eiland
    brian eiland Senior Member
    Hi Nick,
    Welcome back to the forums, and this discussion in particular. I do welcome your contributions, particularly with illustrations.
    Here is the problem I have with that diagram/analysis. That one vector component of your backstay force has a vertical ‘upward force’ to it. There is NO way in the real world that a sailboat’s backstay can pull ‘upwards’ on the masthead,….. horizontal at best.
    I wanted to know what that horizontal force needed to be to offset the forestay’s forward force, regardless at first of what compression loads it was placing on the mast itself (that would come later).
    So what forestay forward pulling force do I need to balance? The one presented by the 2 ton forestay load,...it’s horizontal component being 0.813 tons. Thusly, a backward horizontal force of 0.813 tons which translates into a backstay force of 2.25 tons ?
    https://www.boatdesign.net/attachments/dscf9591-jpg.190750/
    If I take your backstay load of something approx 5.5 -5.76 tons, and look at its horizontal component of 2 tons, ….that’s quite a bit in excess of the 0.813 pulling forward ?
    Is my analysis in error?…..where??
  3. brian eiland
    Twin Backstays
    I have always liked the idea of twin backstays,... to divide up the loading that each one carries, and the loads to the hull attachment points. I most cases its difficult to get this 'twin loading', as invariably one side goes slack due to slight migration of the masthead athwartships. I'm hoping to solve this by making the twin backstay(s) one continuous line that wraps around the mast at its upper connection ...or other solution?
    Actually I am hoping to have BOTH of of my backstays (masthead and hounds) capable of performing similarly.
    It might involve a method of wraping around the mast tube itself, or some sort of sheeve or 'loop' solution,....
    https://www.boatdesign.net/threads/attaching-rigging-to-the-mast.68435/
    https://www.boatdesign.net/threads/soft-rigging-solutions.47997/
    Here is what those twin backstays look like on the model yacht,..
    Will Gilmore likes this.
  4. Nick12345
    Likes: 3, Points: 3
    Nick12345 New Member
    Hi Brian,
    I can assure you that the upwards force described in my diagram is most certainly correct. This is because it is created, not just by the tension of the backstay, but by the combination of the tension of the backstay AND the compression load on the mast.
    The following diagram shows your forward leaning mast and back stay only (we'll ignore the forestay for now). If the mast is free to rotate about its base and supported so that it doesn't fall to port or stb, gravity will hold it in place as it leans forward. That is until we start pulling on the backstay. At this point it will start to rotate about its base and the masthead will follow the green arc - and in doing so move upwards! This is were the upwards force comes from. Each line in a vector triangle is always a COMBINATION of the other two sides. Each line must also always represent the direction of the force. The direction for the back stay and mast follow the angle of each component and the third vector which represents the rotational or torque force at the masthead which, if the forces are balanced and the mast head is static, is represented by a line tangential to the arc of rotation - yellow line in the diagram.
    Now that we have established the correct angles for each vector we can give a value to one side of the triangle and find the balancing forces for the other sides. Working out the forestay is done in a similar way. The first to vector angles are the angle of the mast and the angle of the forestay and the third vector angle is again a line tangential to the green arc that also happens to be perpendicular to the mast. My original is correct and would indicate that a 2 ton static load on the forestay will result in some considerable forces of tension on the backstay and even bigger compression on the mast. All of this means more material in these components which means more cost and more weight aloft. This is always going to be the the disadvantage of a raked forward rig configuration. Not impossible though.
    I am assuming you are familiar with the Dazcat Artemis?
    Accessible Expedition Catamaran - The Multihull Centre https://www.multihullcentre.com/multimarine/current-projects/accessible-expedition-cat/
    They use a similar aft-mast, headsail only set up, but the have kept the mast raked aft as this will reduce rig loads dramatically.
    Hope this helps
    bajansailor likes this.
  5. brian eiland
  6. brian eiland
    I'm still thinking about the modifications I can make to my rig's staying.
    In the mean time I just ran across this posting I made on another forum. It may help to explain why I became SO INTERESTED in this headsail plan,...
    Excellent list of many of his papers in PDF form
  7. brian eiland
  8. CarlosK2
    Likes: 122, Points: 63
    CarlosK2 Senior Member
    To place one sail behind other is a very typical thing to do ...
    the ridiculous idea of a mast leaning forward with an absurd and delirious rig is quite another thing.
  9. brian eiland
    Carlos,...I suspect you have never read back thru much of this rather long subject thread,...perhaps that would be appropriate before adding your criticisms?
    ...for instance this posting of mine, Aftmast rigs??? https://www.boatdesign.net/threads/aftmast-rigs.623/page-7#post-198605
  10. brian eiland
    ...or you might have a look at this posting,... Aftmast rigs??? https://www.boatdesign.net/threads/aftmast-rigs.623/page-7#post-198774
  11. brian eiland
    Structure of the Vessel to Support Rigging Loads
    have a look here,... Sail Loading on Rig, Rig Loading on Vessel https://www.boatdesign.net/threads/sail-loading-on-rig-rig-loading-on-vessel.2293/page-4#post-114487
    bajansailor and Will Gilmore like this.
  12. brian eiland
    What are those 2 long poles stretching out to either side of the vessel from the base of the mast??
  13. brian eiland
    I forgot all about this design ! If I recall I never was able to get in touch with the owner or anyone that could provide additional info
  14. wet feet
    Likes: 633, Points: 113, Legacy Rep: 124
    wet feet Senior Member
    Those poles are the outriggers that provide the anchorage points for the shrouds,both upper and lower.The very generous angles that this arrangement permits are such that no spreaders are used.One interesting aspect of the designs is that you won't see any rigging wire,it is all done with modern polymers.It is interesting to study several aspects of the boats as they are driving progress in control systems and autopilots.
  15. brian eiland
    Yes that what I thought they were, but I wanted someone else's confirmation.
    That's a nice photo you provide for an 'at dock view'. I don't think many marinas would have accommodations for vessels rigged like that.
    My latest alterations to my aftmast rigged vessel would have some spreaderless shrouds (along those same rigging thoughts),...but they would be anchored to the wide beam of a possible bit extra wide multihull vessel itself, .....rather than outstretched poles.
