Advice for new owner of Mercruiser MC-1 drive
Discussion in 'Sterndrives' started by utskicat, Dec 29, 2015.
  1. utskicat
    utskicat Junior Member
    I am the proud new owner of a 1975 Fiberform 19' Monterey skiboat. I've used several YouTube videos to identify it as a pre-alpha MC-1 drive. (It has the loop on the top of the outdrive.)
    The boat's engine was replaced a few years ago to a Ford 351W. Engine runs great.
    I have read several places that it is important to check/replace the water impeller and exhaust bellows if age is not known.
    I'm curious if you guys can suggest a list of things I should plan on checking/replacing on the outdrive to ensure it runs for many more years. I have oriented myself with the basic vocab, but I'm a noob at outdrives, so feel free to explain in over-simple-terms. Post links to good YouTube videos explaining processes if you have any.
    I'm good with cars and a fast learner!
    Also, do I need to change any of the oils in the outdrive?
    I found this kit for bellows and hoses, is this a good start? http://www.iboats.com/Transom-Seal-K...view_id.172480
    Thanks!
    The drive has gear oil that should be changed regularly. Also, when you take the drive out, you can grease the u-joints (they are automotive) and the splines on the input shaft. Remember to put it in forward gear before removing, or the shift arm will be damaged.
  3. utskicat
    Thanks! Anything else I should replace since the boat hasn't been used much in the last few years?
  4. gonzo
    Check that the intermediate shift cable moves freely. If it binds or is hard to move, the engine will stall when shifting.
