My concept would be to add below the hulls but not all of the addition would provide buoyancy.
It would be divided into sections some sealed others floodable.
I have drawn a sketch however do not seem to be able to upload it, do I need to put it on a photo hosting site first?
I had not used the upload feature here before so not sure - I just uploaded mine to imgur.
I had been thinking something similar - any rear extension could be made deeper than the rest of the hull, but rather than floodable hull up front, I would add a streamlined frame between the hulls up the front to act as 'legs' for it to sit on when on the sand. The downside being having extra drag, structure for marine life to grow on, and still needing a reasonable surface area to avoid it sinking in when sitting on soft mud (which we do frequently on our existing houseboat).
I like your idea of adding extra bouyancy below the existing hull though, to avoid extending out the rear.
I think the simple thing is to splash the boat and start moving things around and/or adding some weight.
I did some experimenting with people on the front - 300kg or so standing on the front deck moved the waterline down around 9mm. There is a lot of bouyancy up front, and a lot of weight aft, so I think the amount of weight needed to trim it down at the front is excessive. Plus the freeboard is not massive so I would prefer to add buoyancy to balance it, rather than ballast.
We could give you more accurate and practical advice if we knew the shapes of the hulls as well as current draft and trim of the boat.
I am not very graphically inclined so I am still working on a diagram, but I think I included everything about the hulls and draft in the first post?
So mostly it is cat hulls - rectangle in shape, 1.2m wide (each), 12.1m long (waterline), 0.58m high until the bridgedeck. 1.8m between the hulls.
Then the front 1.8m between the hulls is sealed, and the front is like a punt. The rear of the sealed section is vertical and the cat hulls just extend back from there.
At the rear between the hulls is a 4.8m long, 1.18m wide, 0.5m high tank with a streamlined bow on the front (0.6m, not included in the 4.8m). The front 2.4m of the tank is the sullage tank, and the rear is just sealed off and used for extra buoyancy.
The current draft is 7.5cm at the front, and 19.5cm at the rear. The bottom of the hulls are flat, and it is very rigid, so it sits 1cm deeper into the water for every 1m you move towards the rear.
Based on adding up the immersed hull area, or weighs around 4900 KG.
Personally, I’d start cutting things off.
That massive top deck looks ridiculously too big.
Compared to some houseboats i have been on, I actually felt the top deck was small! It.s 2.2m wide and 10m long. It's a bit under 1/3rd of the downstairs floor space, and around half of the actual roof.
I still need to measure everything used on it and see how much it weighs, but it's not massively heavy duty aluminium, and the panelling is not too heavy.
Otherwise to the rear most of the weight seems to be in the extra structure for the stairs and stairwell, bathroom on the other side and various sections for storage. While this could all be chopped out and moved, i don't think it would be economical for me to do so, even if the boat was significantly cheaper.
Also, if the roof is designed to support a live load of 48 persons or even 12; it is massively overbuilt. You can probably see the added sections from below.
Yep, the roof has some chunky extra support beams in the middle of the main downstairs section. Since as a houseboat we don't need to be rated for loads of passengers on the room, the plan is to remove them and add some supports across to the side, so the area is then totally open. The actual roof itself is marine ply, with a fibreglass cover, sitting on aluminium crossbeams.
Possibly you could bridge the gap between the catamarans and then plate it, turning the cat hull into a monohull.
Good thought - but correct me if I am wrong, is the entire gap between the hulls was plated in, then the buoyancy would be increased equally down the length, which would result in it sitting higher in the water, but still with the rear deeper than the front? (it should even out a little of the tail heavy trim though, since the punt bow is already sealed between the hulls, so if already adding buoyancy to the front?)
Sealing just the section behind the balance point is an option, but since the tanks take up 2/3 or so of that space, the increase is not enough by itself from my calcs. It could be combined with a rear extension too, which could also be a mono hull, which reduces the length needed. But I am not sure how that will effect how it goes through the water - it will be big and slow anyway, so I imagine it won't handle too much different.
From your statement it appears that you do not understand that buoyancy is a function of the displaced volume NOT the horizontal cross sectional area . Cross sectional area x depth of immersion
Vertical sides or not, the deeper the hull is immersed, the more buoyancy the hull provides.
Yep, I worded that poorly - apologies for the confusion, the precise terminology is new to me. All I mean is that (for example) if it was sitting level, the weight to immerse the hull 1cm (379kg) is the same for every additional cm of immersion, because of the vertical sides. Unlike my current houseboat, which has rounded hulls that flair out up to the bridge deck, and take an increasing amount of weight to immerse them each additional centimetre.
What's the most accurate way to express that? That the buoyancy increases in a linear fashion?
SamSam probably has it right. You don't want to extend the length, so move the sullage tank forward. Not sure exactly from the 3 pictures what you meant by a floatation tank. Is this
a tank that exists but is not immersed, a provision in case the other hulls are ruptured.
In any case, you might be able to move the sullage tank ahead and incorporate it into the third half pontoon and if the floatation tank is not immersed now, make it immersed and contained within the
third pontoon.
I added another pic to the album from the rear that shows it. -
Imgur https://imgur.com/qxOYS7D
So the tank starts at the rear of the boat - about 1m behind where the actual cat hull rear waterline starts (under the square sections at the rear are outboard mounts). The tank is a 4.8m long, 1.18m wide, 0.5m high tank with a streamlined bow on the front (0.6m, not included in the 4.8m). The front 2.4m of the tank is the sullage tank, and the rear is just sealed off and used for extra buoyancy. The bottom of the tank is level with the bottom of the hulls.
So currently that tank sits about 20cm into the water at the rear and around 15cm at it's front. The sullage tank is currently empty (and never used).
The bathroom is in the rear structure, and piped directly into the tank. It is a standard (Australian) low water use house style toilet, with a full size pipe into the tank. There is a long aluminium pipe from the sullage tank right through to the rear of the boat for connecting up to a pump out station.
I don't think the tanks can be easily separated. But yes ideally the entire length would be moved forward until the right point so the sullage portions weight when full is spread equally front and rear. And then another tank added behind to extend back out to the rear, adding buoyancy.
I don't have enough experience to know how big a job that would be, so that will be something I will ask when I can get a marine surveyor out to go over it.
I had been mostly focused on the idea of building an extension and connecting it to the rear, so I am loving all these different suggestions of ways to correct the trim!
