Adhesive for laminating two sheets of plywood
Discussion in 'Materials' started by Briank2, Apr 7, 2023.
  1. Barry
    Likes: 643, Points: 113, Legacy Rep: 158
    Barry Senior Member
    While flat bottomed there is an downturn in the bow area. If the piece was a single 18mm/3/4 inch it might be very difficult to pull the bow hull sheet down to the stem.
    2 - 12mm, if the first was screwed down and then the second put over the first would allow an easier bend. (though a thicker and heavier bottom)
    I agree that either 18 or 24 finished thickness and then adding fiberglass will make a bullet proof hull bottom.
    Pulling a single stiff 18mm sheet down will require the screws to be constantly loaded.
    Does anyone think that an 18mm- 3/4 inch ply can be pulled into the curve as shown above? (without a lot of preload?)
  2. Milehog
    Likes: 183, Points: 43, Legacy Rep: 215
    Milehog Clever Quip
    One heavy sheet will always be fighting to tear itself away.
    Barry likes this.
  3. fallguy
    Likes: 2,037, Points: 123, Legacy Rep: 10
    You can kerf the 18mm and fill with thickened resin.
