I've started building a plywood flat bottom skiff. Going to laminate two sheets of 12mm plywood for the bottom. If I can avoid the expense of marine glues and epoxy resin, I'd like to. I do plan to use epoxy when fiberglassing the outer hull and I'm using Bostik Marine for the rest of the joints.
Theoretically, it should stay dry between the two sheets...I will use lots of screws too, so can I get away with Elmer's Contractor Grade Probond, or should/can I use laminating polyester resin? Or something else???
