Squidly-Diddly
Senior Member
- Joined
- Sep 22, 2007
- Messages
- 2,020
- Reaction score
- 190
- Location
- SF bay
You could unroll the tarp as you go, but like you say a cloth like tarp will need something to prevent edges from dipping and allowing water to flow into bottom which is why I suggest a tarp/path with some stiffness just enough to stick up when middle is bent down. Maybe from factory creases/fold-lines on the cutting board so there is about 12" wide walking path and 24" sides on each side. The sides could taper since tall walls only need on the water/boat end of walkway.Promising idea, but how does someone spread out the tarp before walking ashore without themselves sinking into the water mud mixture?
Would a thin and small floating perimeter be needed, to keep the topwater gaps water from pouring in thru the indents, as someone walks on the tarp, causing below-surface depressions? But, Floating perimeter might make it more difficult to set up and take down?
Hope this helps.
But maybe a tarp with some Pool Noodles would work.
