I can't fully tell from the photo, but looking at the one above where you say
'Western Red Cedar planks for the stringers'
The matting looks like it hasn't been worked enough, a few patches of the matting look a little dry but as there is plenty of goop on the edge I suspect it might have benefitted from a little more stipling or rollering (however you did it).
If you look at a single strand of glass closely, rub it between your fingers and you'll find it's actually made up of hundreds of much smaller fibers. If you can
work the resin into and between these fibers it will become transparent and also result in a much stronger finished item.
Don't worry about the one you've done there - you've beaten the factory quality and how long had that lasted
The fillets look great - I only mentioned the one above as I find it's common for people to apply more resin so that it can soak in, when they can get away with less by working it deeper into the strands more effectively - this gets to be a useful technique when you're working upside down and you don't want the excess running everywhere. The racing guys often talk about the perfect ratio of resin to glass when a few extra pounds of resin make it heavier without adding strength...
I am not trying to be critical, it is offered as a suggestion that I hope you can use. Think you're doing a great job and you'll have a fantastic boat when you're done;- the itching goes away after a few days
(usually about the time you discover the next bit that needs to be ground out/sanded, dammit)
