Note: This feature may not be available in some browsers.
Usually, mass is added to the outside edges to dampen roll, from my limited understanding.
The location you chose would not be ideal.
I believe two saddle tanks on the outside edges that can be emptied would be better.
A keel is offset by a mast to dampen the roll. If you don’t have a mast, a keel mass increases the roll, from my understanding. I believe it becomes a pendulum with no counteracting mass. This is experienced in real life by dismasted vessels or vessels traveling to get their masts added.
So, the better plan is to use ballast tanks, I believe on the sides. When underway, or say in bad weather; you drain them, and you flood them for overnight to dampen under typical chop. Probably something like 20 gallons a side or maybe only 10-15.
Hopefully, someone credentialed will reply. I think if you post the immersion rating of the hull, it would make people more comfortable. Noone wants to help you sink, eh?
Now, I suppose you may argue the hardtop is like a mast, but it isn’t. The mass is too spread out.
You can test the theory I’ve offered easily.
Take the boat to a dock and put 4 sand tubes in the middle of the boat, say 200 pounds. Push the side of the boat down a given amount and release it and count how many times the boat rocks before practical rest. Then take the tubes and put 100 pounds on each outside edge and repeat the test. Pretty sure the outside edge will be less time/less cycles to get to rest.
My thoughts, having considered C.G. impacts on my current project. . . .
Make the camper piece as light as possible
Design the boat furnishing and components so that as much weight is as low as possible
Consider water ballast, if needed.
Being wider (beam) will allow you to be taller (camper)
Could also add bilge keels…not sure about the design, but probably something above the planing area of the hull that when the hull sinks or ballast is added also dampens roll.
What did you ‘strip’ out? A thin glass hull may have needed support.Everything will be built very lightly. I'm struggling mentally with that since I like to over build, lol. The base hull when done will be much lighter then originally built. They used DF 3/4" for the stringers, transom and deck, and the console was reduculously heavy. Once stripped the actual thin fiberglass shell weighed very little. That is part of the reason why I am considering adding weight back.
You should trust me on not adding keel weights; it is the wrong way to go. A trawler is built with a deeper vee, in general, and ballast is sometimes added to get to dwl. Your hull shape will not benefit from central weights along the keel. Whoever told you this is broad brushing the concept across all hulls.
