MorrisCode
New Member
- Joined
- Mar 2, 2025
- Posts
- Reaction score
- Location
- FL
Hi, on these old P19s they first had no longitudinal reinforcement. Later they had stringers and eventually I heard they had a horizontal bulkhead because the bows were still tearing off.
I've taken the deck off mine. I have some .5" rigid foam to make a bulkhead out of. Few questions:
-For the bulkhead, should I do one or two layers of 6oz cloth on each side?. If 1 should I orientate it 0/90 to the hull or bias? If 2 layers I'd assume I would lay one each way.
-When I glass it in is it enough to just attach it with glass tape on the top side or should I cut holes in the bulkhead and turn the boat upside down so I can glass it in on the other side too?
-There's an additional vertical bulkhead in front of the beam. Should I cut a slot in it so the horizontal bulkhead is one piece or can I just cut a piece to fit in that space?
I've repaired tons of beach cats before just never worked with rigid foam for construction. Thanks for any help
