I have done something similar to a tremolino,, I added about 200mm of polyurethane to increase freeboard and build in floatation in case of hitting something. I plan to solo my boat and poke around basalt coast line. The daggerboard case took a lot of time, in my case I should have added beam more so than depth . . 2 layers of Polyester with chop mat then 3 coats of epoxy. Fairing the bow was time consuming.
I have experience with fibreglass but far less experience with boats than most people here.
My next perhaps slightly hair brained idea..
I plan to add more to the stern and have a plumb bow, but I wont use foam, making a form by bending on cheap 3mm melamine laminate screwing it on then laying a light glass . Then take it off, glue the glass on to the prepped surface of the original hull, re use screw holes ,alternately removing then filling with resin mixed with silica. then build up layers of glass to finish
I will remove some rocker so a mini keel will be glassed in to take loads underneath the form.
The steps would add the buoyancy.
The polyurethane became slightly damp although not adding much weight after being on the mooring for a 5 years , possibly absorbed from the inside ..all polyester..
I'm not an expert, but doing it this way means inspection holes can be made in the original rocker void created which works for me ,, although I can cut through my original hull ,remove foam and do the same. I'll need to move the mast aft if and when I go through with this.
I slowed my trem down a bit[no significant extra length] but I feel more at ease on my own, now I just have to not fall off... Hopefully this is of some use to you.
