Adding additional stringers
Discussion in 'Stability' started by dada73, Nov 4, 2023.
  1. dada73
    dada73 New Member
    Hi I'm Chris and this is my first post here. Been reading a lot of threads on this topic though.
    So as it happens to others as well I'm about to replace all stringers and bulkheads.
    And as I'm doing this I'm asking myself if it wouldn't make sense to add stringers to further strengthen the boat.
    Options are a center stringers or one or more offset stringers.
    What do you guys think?
    Sidenote: What I definitely want to add is some transom knees to support the engine.
    Ah and we are talking about an 18ft Ski raceboat with a Yamaha 225 6cyl in the back.
  2. ondarvr
    ondarvr Senior Member
    What makes you feel the original build wasn't up to the task, did it fail in its prior life?
  3. kapnD
    Likes: 541, Points: 113, Legacy Rep: 40
    kapnD Senior Member
    If you’re not removing the existing stringers, you could add layers of FRP over them for added strength.
    Adding 2 full stringers will definitely stiffen the boat up, if that’s what it needs, but at a weight penalty.
  4. dada73
    dada73 New Member
    existing stringers are rotten and need to come out.
    Boat didn’t fail but "factory production" is always a compromise btw. good enough and still being cost effective.
    So thought about an "as good as it gets" construction.
    Here's a picture of the bow section.
    The serail shot shows one stringer knee intersecting with the first bulkhead. The stringer is not continuous but rather interrupted but the bulkhead. Most constructions are vice versa meaning the bulkhead is in between the continuous stringers, right?
  5. ondarvr
    What you see is typical construction for the that time, it's piss poor, yet didn't fail, and other than rotting, most didn't.
    What it means is that it was adequate construction for the decades of use it experienced, even with rotten wood. How do you expect to improve on that by adding more structure, weight and $$$.
    If you rebuild it close to original, but use much more attention to detail, it will be a huge improvement over the original build without additional cost or complexity.
    kapnD likes this.
  6. dada73
    dada73 New Member
    Gotcha. I'll add some knees but other than that will stick to the current layout.
    Thanks
  7. dada73
    dada73 New Member
    @ondarvr reg the bow reinforcements you can see in this pic: do them again like they are with some small wood slats or replace them with something else like a vertical more stringer type of structure?
  8. ondarvr
    They didn't fail as is, but you can do whatever let's you sleep better at night.
