255grizzly
New Member
- Joined
- Jun 18, 2016
- Posts
- Reaction score
- Location
- Berkeley, CA
Hello,
I sail an Olson 25 sailboat single-handed (this boat http://sailboatdata.com/viewrecord.asp?class_id=3515). I am considering adding weight to the bilge and was wondering if this forum would have some advice.
Normally, O25's are sailed with a crew of 4-5 people, 3 of whom are usually on the rail. I like to sail it singlehanded, which really creates a problem when it's windy and choppy. It can be very hard to keep the boat flat and there is lots of leeway. I have reefed and used smaller headsails - both of those help some, but not as much as I would like. So, I am wondering:
1. Would it make sense to add weight in the bilge?
Note: I'm ruling out complicated / expensive things like adding a bulb keel or moveable water ballast.
2. If so, how much should I add?
Let's say there's ~540 pounds on the rail (3 guys, 180lbs each)... do I need that much? Or because the weight would be in the bilge/lower in the boat, less?
3. Where should I put it, right over the keel I assume?
4. Is it okay to use a water ballast bag for this?
I would make sure there was an enclosure to hold it properly. But I like the idea of using one of these because they look relatively inexpensive (I saw some for wakeboard / ski boats.) Also, vs. lead shot or lead ingots, it will be relatively easy to install and relatively easy to adjust. And, it won't affect the design / ruin it for true one design racing.
Thank you for your input!
