Actual real life boat being built
Discussion in 'Powerboats' started by Verytricky, Dec 9, 2009.
  1. MrW
    MrW Junior Member
    Nice update. How did You join the deck with hull? Just fiberglass?
  2. Cookee
    Likes: 20, Points: 0, Legacy Rep: 469
    Cookee Boat builder and racer
    Gel, mat, balsa and more mat, the idea is to have the same layup as the bottom, sides and deck of the boat to make a single structure without any one seam or join - every layer is staggered to achieve this.
    We will end up with an incredibly strong boat, but it has to be tilted onto its side whilst still in the mould - quite an achievement with a 34' hull still in its mould!
  3. Cookee
    What we did this week! Two views of the pick-up arrangement for the custom GRP fuel tanks - it's a diesel boat and this is made using Scott Bader's diesel proof resin, the hose will be attached to the brass pick-up and the tank is divided into two.
    The boat has been joined on the port side already and we are working on the starboard side now, the boat still inside the moulds is a bit of a weight and so needs careful handling to turn it on its side!
    Hope to get the boat out in the next few days.
    The other boat is a Phantom 19 that we also make for racing - that will be racing next season in Offshore Circuit Racing.
  4. 26 Spyder
    26 Spyder Squadron XII Fanatic
    What resin are you using? How long are you waiting between additional layers of material? Any additional prep before each layer?
    Thanks.
  5. Cookee
    Polyester resin, no extra prep between layers and we put the next layer in as soon as possible - we don't work 24 hours though!
  6. Cookee
    A big day today, we released the deck last night and floated the hull free in the mould after turning it back to the upright position. The next step is to make lifting points, move it outside and lift the hull out of the mould - put the two halves of the mould together and get the boat back in the workshop for fitting out - more photos to follow!
  7. yipster
    Likes: 98, Points: 58, Legacy Rep: 1148
    yipster designer
    working hard Cookee, getting quit a looker :eek:
  8. 26 Spyder
    Gotcha, thanks. New pics look awesome!
  9. Cookee
    It's out of the mould guys! Very proud of what we have achieved - Kevin and Willy have worked wonders since last Christmas and it looks like it's doing 100mph just sat there! :D
    2 people like this.
  10. 26 Spyder
    I love the lines, definitely not mainstream! At least from what runs here in the US.
    Look forward to hearing how it runs. Keep the pics coming!
  11. Verytricky
    Likes: 17, Points: 0, Legacy Rep: 400
    Verytricky Large Member
    I think we are all looking forward to see how it runs!!!
  12. MrW
    MrW Junior Member
    Damn. Whole project is just awesome, boat looks really sharp. What type of engines will You guys use on that? Sterndrive, inboard or outboard? Also how many hp?
  13. Verytricky
    Personally, given the sea state in the UK, my ideal drive for this boat will be two 550hp engines with twin DPX drives, so it has push the whole time whilst driving. I would expect to do a solid 90mph+ in almost any sea state. In some races the boats are down to 30mph due to the sea state, and I think this hull with this drive setup would definately not worry about the rough!
    The first boat will be fitted with surface drives, which will be vey quick in the small slop, but I fear will loose traction, over-rev and have continual engine retarding in the very rough.... This will not be as bad as with other surfave drive boats of this length - the design itself helps the boat sit in th ewater more and is much less flighty in rough water.
    But what do I know? It is just a feeling based on looking at other similar boats, and really - there is NOTHING similar in design out there at this time...
  14. 26 Spyder
    Updates?
  15. Mr Efficiency
    I hope nothing went wrong doing 90mph plus in " almost any sea state " ! Leave me out of that one.
