sdowney717
Senior Member
- Joined
- Nov 13, 2010
- Messages
- 1,600
- Reaction score
- 118
- Location
- Newport News VA
The ABYC standard of connecting the 12V neg buss to the AC ground buss, (green wires,) dates back to the time when boats had quite rudimentary DC systems and shore power was an extension cord to run a battery charger and a few outlets, and if you had a bigger boat you might have a water heater.
In those days the engine was "Grand Central Station" for all the DC grounds, and provided a low resistance path to the water.
To keep people on the boat from being shocked they connected the AC ground buss to the DC ground buss for the same purpose, to provide a low resistance path to the water.
That was all well and good in the old days WHEN BOATS HAD ALL THEIR UNDERWATER METALS OF BRONZE, (highly noble).
Today boats are mix-masters of less noble metals all just waiting for a few electrons to start eating away at some fitting.
But as the vid I posted shows, putting AC into the water is not good if there is somebody in the water nearby, and sending electrons down your prop shaft doesn't help the underwater metals either.
Today we can do better, we have RCDs, GFCIs, and other devices.
To repeat, a GFCI does not need a ground to work, it senses imbalance between the black and white.
But we want the green wire, it's a SAFETY ground, it's the low resistance path back to the source of the power, (the dock,) should a GFCI fail in the "On" mode.
PUT A GFCI BREAKER ON THE DOCK POWER TO PLUG YOUR BOAT INTO, that's your first line of defense.
Use a GFCI breaker in the boat at the inlet of the AC, that's your second line of defense.
Put GFCIs on EVERY AC device in the boat, that's your third line of defense.
Keep your AC wiring up high and dry in the boat, don't run AC wiring in a bilge.
STOP ANY AC ELECTRONS FROM GETTING TO YOU OR THE WATER.
If you have to connect the AC and DC busses together for the surveyor, (usually for insurance purposes,) do it.
If you don't have to do it make your own decision.
The green AC ground is the minimal and last line of defense for sure.
At least all AC wires have such a wire, so it's no big deal to hook it up as a mechanical ground.
GFCI definitely is an amazing device. The newer ones of the last few years auto test themselves even continuously. If the self test fails, then they turn off the power.
All mine are self testing, and they also have the manual test button.
These things have logic circuits, and built in firmware, they are aware when something is not right.
The AFCI GFCI Combo breakers are also tons better than when they first came out years ago, They are smart, they look at the AC waveform to determine if wires are arcing. I have not had any combo breakers shut off when running AC brushed motors.
Ss the GFCI protects your life, and AFCI prevents electrical fires caused by arcing wires.
My combo breakers are Square-D.
You can get an arc with loose screw connections to devices using AC power. The arc creates heat, and also points to high resistance connections, these things get so hot they cause things to smoke and burn.
An ARC Welder is a good example of a high current arc, and it is so hot it melts metals. AC wire arcing is a similar thing, just not as much current is flowing, but could flow 30 amps.
