AC 37 -like before but with a little less and a little more...
It appears that foiling monohulls are here to stay. At least for The AC.
The technology works reasonably well, and is a way of keeping with monohulls (catamarans are faster foilers).
Indeed, foiling seems to be the last word in scalable sailboat performance.
So, it's only natural for the AC to embrace it.
But it seems different from the 12 meter class old days. I find myself more and more indifferent to the competition, as it seems to be dominated by a small mafia of sailors who seem to be completely mercenary.
I suppose this is at least partly because most sailors will never own or even sail on a foiler. They are incredibly fast, but must be kept extremely light in order to work.
True enough.On the other hand the lifting foils on a cat can have a greater amount of lateral separation from the rig and the windward hull is even further away,which helps the righting moment.I would be very interested if anybody could dig out reliable comparative aero drag figures for both types.I don't doubt it would be too confidential to share and have no realistic expectation of seeing solid data.
Why would catamarans be faster foilers by definition? As speeds increase air drag gets more important and cats drag a whole lot of draggy structure trough the air.
I don't see any good comparison of multi to monohull foilers because these AC 75s are using stored power for ballast management and the configuration is multihull if you go by the foil hull equivalency. Bi-foilers like the Moth are true monohulls.
The real accomplishment of foiling is decoupling speed from size. The new foiling speed limit is cavitation. Below that speed limit is the battle to manage the fairly binary performance -staying up and in control of small high aspect foils. The foils have gotten so small that air drag is more significant.
When not on the foils, monohulls still need ballast, to not just flop over. So presumably the cat is still lighter, once the boat is big enough that constant motion from the crew isn't enough to keep it upright.
Must agree though. I simply don't care anymore. It hasn't been relevant to the art of making seaworthy boats for a very long time. If they set the dates a year and advance, and ran the races absolutely without regard for the weather that day, I'd pay some attention.
I'd love to see some of these decadent monstrosities fighting it out in sea state 5. Or cowering in port while some folks in a real boat take it all.
I am quite pleased with the foiling cat one design series and none of them would exist without the SF AC. The "Sail GP" is a great show -particularly in borderline conditions that they don't have much experience in.
The "new" AC 75s are the least interesting aspect of the protocol behind
-new AC 40s to be raced in youth and women's tournaments.
-the chase boats are to be hydrogen powered -this is a big opportunity for fuel cell electric boat development. GM just made a move on electric boat power. They should be best positioned for this chase boat contract with their fuel cell tech.
For two reasons:
1.) No.ballast, so less weight, and
2.) Greater distance between the main lifting foils.
Also, two slim hulls are easier to push through the air than one wider one, even if the beams of the two narrow hulls add up to be the same as the wider hull.
Although there will definitely be more friction drag (because of more surface area for the catamaran), that is nothing compared to the parasitic drag of the wide single hull.
Either sailing on the water, or foiling through the air, the multihull offers the most bang for the buck when it comes to speed.
But the AC has never been about bang for the buck. It's often been about the opposit.
Yes. Make sure to spend as much bucks as possible, to keep out the lower classes.
The '88 races were extremely interesting. Just for the look on Michael Fay's face.
I have an idea that I already launched on Sailing Anarchy the day they issued the new protocol.
Protocol for the 37th America’s Cup https://forums.sailinganarchy.com/index.php?/topic/227617-protocol-for-the-37th-america%E2%80%99s-cup/&do=findComment&comment=7732586
Here is the idea, It's bloody simpel. Use photo electric Voltcells molted into the deck as an extra bonus for battery 60 volt charge.
Use the same cells of the solarchallege if you do not want to do research, but in case of endless financial supply, invent a better one and be usefull for the planet.
They reacted somewhat positive maybe Dalts is considering to take the extra option into the final, not draft, version. He stated there were al lot of days not sunny in for instance Portsmouth.
Also the final location in the cup, Auckland has a lot of not sunny days.
My idea is as follows but has to be described in the regattarules.
Make a green flag when lurking (extra shore power ) is prohibited.
As counter argument they came up with the extra weight disadvantage.
That's not a problem if every team is obliged to do so.
Most effective PV cells might be to costly and too vunerable for water leaking.
How do my fellow engineers feel about this plan?
It might safe the weight of grinders in the best case.
Looking forward to constructive remarks....
The "Challenger of record" system is problematic, but it has been for longer than I have been following it, and yet this is the oldest competition there is. AC36 was the maximum exploitation of this -the leading team had a special deal with their chosen challenger to be with the winner in isolation from all others the second they won. As a result, the multihull form (that all others agreed to) was dropped. Despite the radical change, the cup went on with a reasonable amount of challenge and thankfully, not excessive lawyering. The sailors and engineers certainly influenced the result far more than lawyers. I guess that is my measure of success for the process and I consider the right to choose the protocol the real prize of winning the AC.
It is very interesting that Earnesto is returning, and that F1 teams are partnering. I certainly hope it is because F1 teams are looking for high stakes racing that is carbon free, rather than F1 teams looking for spending cap chicanery.
It is also important to note that the AC is so expensive, that anyone who doesn't like the rules can just start their own series! I don't care the AC got hijacked at 36, because sail GP broke off and is a fantastic one design series -everything I want in multihull AC, just without the name. I am not certain, but it appears to me that AC37 sees this success and is setting up to do the same with their 40ft boats. ESG is influencing racing.
For two reasons:
I don't think you can make any of those assumptions. An AC75 is 6,450 kg, an AC72 is 5,900 kg, so really in terms of kg/unit length, the difference isn't huge (312 kg/m vs 268 kg/m). The new AC75s will be lighter* (maybe 800 kg or so, perhaps 273 kg/m) so the difference is reduced.
The separation of foils and windward ballast gives the AC75 enormous righting moment, plus the foils can be canted. The multis have an advantage in using the windward rudder to increase righting moment, but the rigs are very different so the comparison is moot, particularly as both are limited by class rules so not really the ultimate of either configuration. The AC50/F50 shows what happens with a more open platform and continuous development with small gains.
Lastly, both are highly developed aerodynamically, but they have very different features. The AC75 hull is somewhat more bulky, but there's only one hull and no tramp so I think again they'd be very close in drag.
But the point is moot anyway, they'll never race each other and speed around a course could be tested pretty accurately in simulators (if there's still an AC72 simulator around, perhaps an F50 simulator would do).
* Apparently the all–up weight is about 1,000 kg lighter, but that includes two fewer crew, so 800 kg less for the hull seems reasonable.
