ABS m^2 – m^2 VS cm^4
Discussion in 'Class Societies' started by yanivmass, May 11, 2025.
  1. yanivmass
    yanivmass Junior Member
    Hi all
    Will apprechate if any one can clerefy the conversion of moment of inertia 2024 barge roll units from cm^2 – m^2 to cm^4:
    ABS rules for classing and building steel barge
    3.2.1/5 - Long hull & deck girder standard strength
    The hull girder moment of inertia I amidships is to be not less than obtained from the following equation:
    I = 0.03SMRL cm^2 – m^2.
    I = 0.03 x 0.131 x 38.4 = 0.151 cm^2 – m^2 = ? cm^4
    Where:
    L = length of barge as defined in 3-1-1/3
    SMR = hull girder section modulus required for the barge per 3-2-1/3.1, in cm2-m.
    Thank you
  2. DCockey
    DCockey Participant
    Unit conversion
    1 m = 100 cm
    1 m^2 = (1 m)^2 = (100 cm)^2 = 10000 cm^2
  3. yanivmass
    Thank you David,
    I made a mastake: the fraze is cm^2-m^2 vs m^4
    or in may case:
