Abrasion Damaged Hobie Cat
Discussion in 'Multihulls' started by CardboardKing, Jul 5, 2013.
  1. nota
    Likes: 2, Points: 8, Legacy Rep: 24
    nota Junior Member
    I repaired my $20 hobie 18 by cutting a hole in the deck
    and after the glass work inside was done
    the hole was covered by a deck plate 6'' plastic screw in
    any marine store should have deck plates in 4-6-8'' sizes under $20
    btw long gloves help with glass dust itch from needed sanding prep
    I always wet the glass before placing it inside, on a bit of card board or ply
    and use lite MEK doses but help it cure with a old style lite bulb for heat
    a hairdryer will also work or a paint scraper heat gun
    after the inside glass sets you can fair the outside with your choice of puttys
    bondo is cheap but weak micro balloons or choped glass is better
