A40RC ORC Hull offset file wanted
Discussion in 'Sailboats' started by simon james farren, Jan 8, 2025.
  1. simon james farren
    simon james farren New Member
    Hi There, does anyone by chance have a A40RC 2008 mk1 ORC Hull Offset file please
    I would like to do some orc sail optimization
    Thank you kindly, Simon
    You are asking for proprietary information that they are not likely to provide. If you have one, scanning the hull is possible without too much expense.
  3. simon james farren
    Yes i realise i may well have to do this....a friend managed to get a file for his boat...hence was worth the ask to save scanning
  4. gonzo
    How will the hull lines plan help you with the sails?
  5. TANSL
    How could you design the sails of a sailboat without knowing the shapes of the hull?
  6. gonzo
    It is a production boat. The sails are already designed.
  7. TANSL
    @gonzo, that means, from my point of view, that sail are still not fully designed.
  8. gonzo
  9. TANSL
    A project that has not been attempted to optimize, in any sense (asking that is trying to go off on a tangent), should not be considered finished. (Optimize as far as you are capable or consider sufficient, because probably another designer could improve it still, or even yourself at another time)
