a radical form of propulsion
Discussion in 'Multihulls' started by isvara, Nov 25, 2019.
  1. isvara
    Likes: 1, Points: 3
    isvara Junior Member
    It occurred to me that if propellers were efficient then nature would have put them on at least some marine species.
    When hovering 3 metres above a 2 metre stingray whilst spearfishing some decades ago, I was startled and impressed with how it swiftly distanced itself from me with an undulating ballet like motion at the edge of its body. Upon returning home I cut a piece of thin plywood about 30cm x 30cm, tilted it about 15 degrees in the bath water and pressed down on it firmly with my hand roughly at its center of buoyancy. This obliged the ply to move quickly forwards following its enclined path of 15 degrees until it hit the bottom of the bath. at no time did it vary its tilt due to the comparatively large area. I theorize that if this fin was attached to a suitable vessel, moved mechanically up and down and reversing its tilt on the upstroke with a wave like motion then surely the vessel would move forward like a stingray. It should be very efficient.
    Has anyone ever done any such experiments? waddayarekon?
  2. Blueknarr
    Likes: 232, Points: 63
    Blueknarr Senior Member
    The traditional gondola is propelled with that very movement. Although horizontally not vertically.
    Part of a propeller's mechanical efficiency is its continual rotation. It doesn't have a pause at the end of each stroke. Continual rotation is not biologically possible. Living organisms have to stick with reciprocal motions for propulsion. How many land animals roll on wheels?
    VinTin likes this.
  3. Mr Efficiency
    I assumed he was taking about the wave-like motion of the outer flaps of the Ray.
  4. Tiny Turnip
    Likes: 193, Points: 43, Legacy Rep: 743
    Tiny Turnip Senior Member
  5. Tiny Turnip
    Here is a device using an undulating mechanism for propulsion:
    MassimilianoPorta likes this.
  6. Mr Efficiency
    Wow. I think the OP will agree that is the motion he was seeing with the ray
  7. gonzo
    That theory keeps on rearing its head. However, like paddle wheels, it is simply not as efficient as a propeller. Race boats, which can use any method to create thrust, do not use flaps. Please, do not bring up worldwide propulsion conspiracies. At this point in propulsion technology, improvements are minimal. Until someone ever comes up with a revolutionary system, we will have to live with the physical limitations of present technologies.
  8. TANSL
    Wise words.:)
  9. Mr Efficiency
    You are the only one doing that, that I can see.
  10. tspeer
    Likes: 290, Points: 83, Legacy Rep: 1673
    tspeer Senior Member
    It's not quite the undulation of a stingray, more like the flapping of a manta ray. But the Hobie Mirage Drive oscillates in a biological manner instead of rotating.
  11. isvara
    Likes: 1, Points: 3
    Thanks for the replys and video s. Never been close to a manta but sounds promising. A horizontal dagger board profile, maybe 2or 3ft long both pointing inwards from each hull and driven by a slow but powerful crank system would be an interesting experiment on a cruising cat. In stop position fins would be at top dead center and horizontal. Maybe drag would be a nuisance unless tilted vertically at rest.
  12. tspeer
    And then there's the Trampofoil.
    It has a foil that moves up and down, changing its incidence between the up stroke and the down stroke.
  13. BlueBell
    Likes: 415, Points: 83
    BlueBell "Whatever..."
    ...also known as the Exhauster!
  14. isvara
    Likes: 1, Points: 3
    Many Thanks tspeer, it illustrates clearly how the alternating vertical force is multiplied to a horizontal direction.
  15. Niclas Vestman
    Likes: 15, Points: 18
    Niclas Vestman Senior Member
    Maybe gonzo tansl and the other wise men (not wise guys) has a better figure than i do. But as far as I remenber propeller efficiency can reach about 80% max wheras oscilating fin propulsion only reaches about 65% max. But still there are a few reasons as to why fin propulsion might be a good idea in certain special cases. 1) shallow draft, 2) little risk of damage to suroundings, 3) very low noise emission, 4) counteracting roll/pitch/jaw movements 5) recovering energy from wave and boat motions. (There has been prototypes making up to 4 knots of speed only by passive fin propulsion (no motor or energy added to induce movement). Apperently first discovered by whalers who noticed that killed whales hauled alongside ships usualy made about 1knot speed despite beeing dead. Just by the body/tail/fin passively moving in the waves alongside the ship.
