adam_designer
Junior Member
- Joined
- Jul 31, 2010
- Messages
- 57
- Reaction score
- Location
- Banyuwangi, Indonesia
Hi people,
I was opening some thread about epoxy glass on plywood in this link
http://www.boatdesign.net/forums/wooden-boat-building-restoration/peel-ply-plywood-epoxy-18832.html
Then Pericles, directed to a link from duckworksmags which is
http://duckworksmagazine.com/03/r/articles/glass/bottom.htm
which is - for me- is very radical way on finising job. okay here it is
normally you'll get this when you laminate woven roving over plywood
but if you use some step by covering it with plastic and rubbing the surface to pushout bubles
you will get this:
one word. AMAZING. the site stated
"I suspect that if more people saw this film procedure, it would become standard practice"
I cant more than agree with him. Then I have several question.
1. what kind of plastic it is? What it usually used to?
2. is the plywood need to be coated first with epoxy or just in one way?
2. I have some idea on wood deck finishing, will this work?
I will make some trench using rooter on plywood, but the "trench" or perforate lining is not totally cut the plywood. and then filling the trench with some rubber paste or black coloured resin. Then I will apply woven roving and epoxy on ot used the same technique ( I will not use non woven fabric, because it has some thread/ weaving thread that wont dissolve with resin, so it will have white yarn that not transparent) will this technique would be like this?? (but surely it would be glossy)
after that i will spray several PU coat for UV resistance.
Any comment and advise will be appreciated. Thank you
Adam
you will get this:
Adam
