Coyote Boats
Junior Member
- Joined
- Jun 22, 2024
- Posts
- 9
- Reaction score
- Location
- Wisconsin
I’m looking for feedback on a hull shape I’ve drawn for an 8 m demountable catamaran. The design intent is local lake sailing with occasional trailering for multi-week cruising. Think Stiletto 27 with a bit more stability and load-carrying capacity, or a Stiletto 30 that’s a little more travel-friendly.
Specs so far:
The hull has a fairly flat rocker with a slight hump aft, similar to Shuttleworth and Grainger designs. Sections are V forward, U-shaped in the mid-sections, and flat-U aft.
My questions:
1. What can/should I do to further refine the hull shape below the knuckle before I start building?
2. Is the hump in the rocker too pronounced?
3. What should I ask that I'm not asking?
Some screenshots for context:
Center of buoyancy:
Waterplane section:
Body plan:
If someone knows how to add an STL to a post I'd be happy to include that too.
Thanks!
Specs so far:
- Displacement: 1800 kg
- Length: 8 m
- Beam: 5.7 m
- LWL: 7.38m
- BWL: 0.7m
- Foils: Daggerboards and cassette rudders (the boat will be moored in ~3 ft of water)
- Construction: Strip-planked below the knuckle; 6 mm ply on frames above the knuckle
- Prismatic Coefficient: ≈ 0.64
My questions:
Center of buoyancy:
Waterplane section:
Body plan:
Thanks!
