80 foot cargo harryproa
Discussion in 'Multihulls' started by lucdekeyser, Nov 15, 2020.
  1. Gringles
    Likes: 1, Points: 3
    Gringles Junior Member
    Proas are the most important boats because they can do better than normal multis because they are cheaper and faster. And someday after all of the polar ice melts all that will be left in the world after the apocalypse will be cargo proas.
  2. Russell Brown
    Likes: 191, Points: 43, Legacy Rep: 25
    Russell Brown Senior Member
    I think you may only find one person who says those boats are very light and easy to build.
    BlueBell likes this.
  3. Alik
    Likes: 388, Points: 93, Legacy Rep: 1306
    Alik Senior Member
    Yes, yes, we see it... Calm down, take some medication... :D
  4. Gringles
    Likes: 1, Points: 3
    Thanks Alik!
    I've enjoyed researching your sailing monohull designs. The Alien design, and the 8 meter with a forward swept keel and canard are particular favorites of mine.
    Have you ever designed an 8 to 10 meter racing multihull?
  5. Eric ruttan
    Likes: 31, Points: 28
    Eric ruttan Senior Member
    Oh? Do you know a lighter or easier to build design?
  6. Alik
    Alik Senior Member
    Racing multi - nothing which is built. We design cruising multis - the market.
  7. Gringles
    Likes: 1, Points: 3
    Weight to windward proas would need a beefed up righting arm when loaded.. which is probably why the designer is interested in trusses.
    A Pacific proa would make for a much better cargo proa.
    Proa File | The Case for the Cargo Proa https://proafile.com/multihull-boats/article/the-case-for-the-cargo-proa
    This article explains why only Pacific proas will be used after all of the polar water melts and makes the oceans taller.
  8. Gringles
    Likes: 1, Points: 3
    If that's true, then why make the smaller scale prototype with a different rig?
    What specific questions did the full scale prototype build answer that you couldn't get through less expensive, and more specific materials testing?
    I'm interested in better understanding the scope of this project.
  9. lucdekeyser
    Likes: 18, Points: 18, Legacy Rep: 51
    lucdekeyser Senior Member
    I'am quite sure that if all of the forum members participating in this thread would be discussing the same topics around a coffee table or in a bar or even better in each others' building shed we would be pretty much good friends. We all know the vulnerabilities of using a forum when discussing multifaceted topics. Please do not feed negative spirals.
    The idea of a proa cargo is not new. Here is one of such experimental boat sailing with a load of 2.5 ton of pebbles as a prototype for a much larger vessel. I believe this is from the guys of Jours Meilleurs, one of the largest French Proa's (or Prao as they call it).
    DogCavalry and Tiny Turnip like this.
  10. Gringles
    Likes: 1, Points: 3
    The futuristic cargo ship made of wood https://www.bbc.com/future/article/20201117-clean-shipping-the-carbon-negative-cargo-boats-made-of-wood
    Here's a similar project that apparently didn't need to build a prototype to determine the project economics. How did they do that?
    They didn't even build a smaller scale model before building the prototype?
  11. gonzo
    Likes: 2,389, Points: 123, Legacy Rep: 2031
    People that paid attention in middle school science class know that when ice melts the volume decreases. A glass of water with ice cubes filled to the rim will not overflow as the ice melts; neither will the oceans.
  12. gonzo
    The project economics are relatively simple to calculate. It will run at a loss and will only survive through donations and volunteers.
    Alik likes this.
  13. Tiny Turnip
    Likes: 283, Points: 63, Legacy Rep: 743
    Tiny Turnip Senior Member
    People who paid attention in school know that the vast majority of polar ice sits on land.
    DogCavalry, Dejay and rwatson like this.
  14. Tiny Turnip
    Or government funding.
  15. Gringles
    Likes: 1, Points: 3
    Sure... OK... and I suppose you are also gonna tell me you think the earth is round and that rocks are made of dinosaur bones and that Santa works for the Russian CIA. I respect your "beliefs." I simply don't share them. And, that's ok.
