50-200 hp electric pod with nozzle and motor on hub?
Discussion in 'Pod Drives' started by ram68ocean, Jul 3, 2021.
  1. ram68ocean
    Likes: 2, Points: 8, Legacy Rep: 10
    ram68ocean Junior Member
    Would you know any 50-200 hp electric pod with nozzle around the propeller and the electric motor on the hub?
  2. philSweet
    Likes: 648, Points: 113, Legacy Rep: 1082
    philSweet Senior Member
    Curious about your application. Why would you want that combo? There are ducted prop e-drives with shafts, both steerable and fixed. And there are podmotor open drives. I doubt 50+hp can be passively cooled, so a podmotor will have higher maintenance than an inboard with forced cooling.
  3. ram68ocean
    Hi, thanks for your input. This was actually a client's request or suggestion. The client is used to bigger ships.
