5 year old container ship breaks in half
Discussion in 'All Things Boats & Boating' started by Corley, Jun 19, 2013.
  1. Corley
    Likes: 199, Points: 63, Legacy Rep: 826
    Corley epoxy coated
  2. tomas
    Likes: 17, Points: 0, Legacy Rep: 147
    tomas Senior Member
    uh-oh...
  3. Ad Hoc
    Likes: 1,987, Points: 113, Legacy Rep: 2488
    wooaaahhh!!!
    Either poor loading procedure of the containers and/or poor localised fabrication/detailing, or repair, that lead to a fatigue crack which went, zzzzzzzzzzzzzzip!
  4. Angélique
    Hey, now you have two container ships, maybe this is due to different destinations of the containers :D
    Cheers,
    Angel
  5. dinoa
    Likes: 26, Points: 28, Legacy Rep: 97
    dinoa Senior Member
    Salvage should be very interesting.
    Dino
  6. rwatson
    rwatson Senior Member
    Some credit to the NA that designed the ship is due. Most boats would have capsized and sunk after a failure like that.
    They certainly got the watertight compartment design spot on.
  7. Dirteater
    Likes: 22, Points: 0, Legacy Rep: 300
    Dirteater Senior Member
    thanks for the chuckle RW,
    I certainly do see your point, it is truly amazing.
    however it did break in half. :D
  8. jehardiman
    Likes: 1,501, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    Now that the bow fell off, all they have to do is tow it out of the environment.
  9. Corley
    Corley epoxy coated
    My understanding of these ships is that they are constructed in segments if the ship was recovered would it be possible or worth repairing? I recall reading about one ship where engine wear had rendered it unable to meet average speed requirements to be economically viable. They shortened the ship and managed through the reduction in weight to make it meet the required parameters to reenter transport duties.
  10. Manie B
    Likes: 123, Points: 63, Legacy Rep: 1818
    Manie B Senior Member
  11. rwatson
    Well yes, the definitely are built that way - but the suckers are supposed to be welded.
    I would love to see the 'raw ends' to see if someone forgot to inspect the welds at station 48, and see if it was only bolts holding the middle together.
  12. jehardiman
    Photos show she split at the aft end of cargo hold 3 or 4(?) which would be about the loacation of maximum moment when hogging. I wouldn't be suprized if there wasn't some damage to the longitudinals/keel (container hit or grounding) because the photo in post #2 shows a compression failure of tanktop. Also looks like she lost a the whole stow out the end of the breach also.
    Anyway, to answer Corley's question, it all depends on where the damage was. If it was in the PMB, then you could just cut out the damaged cargo hold, but most likely she is a CTL unless they totally rebuild the bow because she would be to small to make a profit (which is measured in pennies per container). Rebuilding would depend on the cost split between new construction/prime move economic life compared to the insurance payout.
    Edit, she is IMO 9358761, ex APL Russia built by MHI Nagasaki
  13. Milehog
    Likes: 183, Points: 43, Legacy Rep: 215
    Milehog Clever Quip
    LOL:rolleyes:
  14. jehardiman
  15. BPL
    Likes: 15, Points: 0, Legacy Rep: 209
    BPL Senior Member
    1. Chapaef
    2. Scott Danforth
    3. BlueBell
    4. sdowney717
    5. sdowney717
    6. Will Gilmore
    7. Tharayman
    8. Ike
    9. magentawave
    10. JosephT
