5-Meter Power Cat with 6kW Outboard
Discussion in 'Electric Propulsion' started by bobkart, Feb 19, 2022.
  1. bobkart
    Likes: 55, Points: 18
    bobkart Junior Member
    An E-Tech supplier answered that their motors can be configured to rotate in the other direction (left-handed). My next question was about efficiency, but they've not answered that yet (electric power in to prop-shaft power out).
    And Propel got back to me about their S1 motor, specifically, about how their propeller design can support a wide thrust/speed range of applications, from tugboat to fast planing hull:
    Seems straight out of their literature. I suppose I could try asking for a plot of that 'broad efficiency map'.
    Flotation likes this.
  2. bobkart
  3. bobkart
    I just got an update from Propel:
    I'm still unsure if this is overall efficiency (electrical power in to thrust out) or starting from the motor output. I.e. is the motor efficiency included in the 73.5% claimed. I'll update again if/when I hear further from them.
  4. bobkart
    On a re-read of what Propel wrote, "includes the complete powertrain" indicates to me that motor efficiency is included. Had it said "includes the complete drivetrain", I would want to factor in motor efficiency to that 73.5% to get overall efficiency. As I read it, the 73.5% is overall efficiency, which is impressive. I think that puts the propulsive power of the Propel motor on par with a 20hp ICE outboard, perhaps even higher.
    Another part of their reply to my questions indicated that they are leaning towards a three-pitch selection of propellers, similar to how Torqeedo does it.
  5. bobkart
  6. bobkart
    She finally got her name applied.
  7. bobkart
    Working on a second, smaller battery, for use as either backup battery (5.376kWh), or to add to the main battery for more range (156 minutes of full power). Could also be used by itself for short outings (~50 minutes of full power).
  8. bobkart
  9. bobkart
  10. bobkart
  11. bobkart
    First saltwater cruise:
  12. bobkart
  13. bobkart
  14. bobkart
  15. Flotation
    Likes: 35, Points: 28
    Flotation Senior Member
    Thanks for documenting and sharing your work. Perhaps a video more focused on the technical details of your electric cat would be nice? It would be good if those details reach a wider audience.
