5.7vortec smallblok350
Discussion in 'Powerboats' started by maxum, May 12, 2007.
  1. maxum
    maxum Junior Member
    hi new here
    can you tell how to tell if the con rods on this engine is to the front?.
    i had a shop to fit new pistons on but they maybe put on back to front:mad: .
    so b4 i put them back im thinking its best to ask.
    thanks.
  2. LORDBLiTZ
    LORDBLiTZ Junior Member
    huh? As long as the rods are the right way on the crank, and the pistons have a 4 valve relief, can't see you having a problem.
    Does the engine spin over easy? The rods that sit on the same journal, have to be flat back to back.
  3. gonzo
    Likes: 1,722, Points: 123, Legacy Rep: 2031
    The locking tabs on the bearings go towards the outside. The pistons should have the notch facing forward.
  4. maxum
    maxum Junior Member
    thanks ,guys thats what im looking for .i know about the pistons.
