4.50m Sailing Yacht Concept
Discussion in 'Boat Design' started by J.A.L, Jul 19, 2016.
  1. J.A.L
    J.A.L Junior Member
    Thanks very much for that. Do you have a suggestion for a program I could use to fiddle about with this myself and maybe to do a full 180 degree test with the cabin?
    JAL
  2. TANSL
    Likes: 414, Points: 93, Legacy Rep: 300
    There are several programs, very good and expensive. I like a lot MaxSurf, I use it often, but mostly use my own application, ARQN, which needs AutoCAD to create the model and draw and print curves and results.
  3. J.A.L
    J.A.L Junior Member
    I don't think I can really justify the expense of one of these programs. Could you please find out how low I need to get the COG for the boat to recover from a full 90 degree knockdown? or, if you can, set the crew weight so that it is on one side of the centreline as if hiking? I think this would make a big difference and be helpful in working out levers etc. for the rigging. I hope this is not too much trouble.
  4. TANSL
    It would help you to make a first estimate of the lightship and the position of its center of gravity. Mine am convinced that it is not too correct, although it was pessimistic.
    It would also be helpful to have the body lines plan of the ship.
  5. J.A.L
    J.A.L Junior Member
    What do you mean by body lines plan?
  6. TANSL
    A drawing with, clearly defined, the contours of the frames, the longitudinal profile in bow and stern, the line of the deck at side and center line, some water lines. Apart, of course whether the pantoque is the curved or straight.
    If you have an ".igs" file of the model it would be enough.
  7. J.A.L
    J.A.L Junior Member
    Would an autocad file of the hull net be ok?
  8. J.A.L
    J.A.L Junior Member
    Here is a .dxf . Maybe this will be easier than using a lines plan for you?
  9. TANSL
  10. J.A.L
    J.A.L Junior Member
    Here you are. Thanks.
  11. J.A.L
    J.A.L Junior Member
    Are you able to do anything with this?
    JAL
  12. TANSL
  13. J.A.L
    J.A.L Junior Member
    Thanks very much. Hope it goes well.
  14. TANSL
    Please, observe and compare the stability curves of your boat with a normal sailboat. Your curves are very poor. The righting arm of your ship becomes negative at approximately 77ยบ. This, for a sailboat, is a very low value.
  15. J.A.L
    J.A.L Junior Member
    I see. It seems to have more dinghy-like characteristics.. I'm not certain but I think the COG may be lower because of the bulb keel so I will do some better estimates on this. It was surprising to see the max. GZ change so much with the passengers to one side. Thanks for the help- I will try and design a more forgiving boat..
