3D From 2D
Discussion in 'Boat Design' started by Windship277, Oct 12, 2015.
  1. Windship277
    Windship277 Previous Member
    Hi all,
    New here, just joined.
    Ive been yacht repair now for 25 yrs, have worked for Alden, Hunt, and have built a Duffy 37 from hull and deck plus 3 boatyards. I know a little about boats. Anyway..hello all.
    I now live in the mountains and design and build R/C model plugs for hulls and decks. However plans for modern yachts are almost non existent. I can easily draw station and profile...so...how do I get sections?
  2. DCockey
    DCockey Senior Member
    Are you asking how to design a hull shape?
  3. messabout
    messabout Senior Member
    If you have plan view and elevation views drawn to scale, the drawings include waterlines, buttock lines, and/or diagonals you can easily measure station configurations. You then develop your own table of offsets and you are good to go.
    If all you have is pictures or outline drawings there is no way to convert those lines to reliable station measurements.
    If you want oldie goldie drawings you can go to the US government Printing Office, Washington D.C.
    For Whaling ships, and many small boats, Try Mystic (Conn) museum. For Vintage work boats and fishing boats, Manatee Maritime Museum, Bradenton, Fla.) If you want McGregor 65s or some such .... I think you are out of luck. Some cool designs, such as the EC12 specifications are available from American Model Yachting Association, AMYA for RC people. The EC12 is a model of the Charlie Morgan Americas Cup boat that he campaigned in the 70s. It is a helluva nice working RC boat, and there are a lot of them, even in places like New Zealand, and fiercely contested across the U.S. It is also a very tightly ruled class and allows only class approved hull builders. There are Lightnings, Lasers, Stars, and other established RC classes., All of which are tightly, and perhaps, jealously restricted for hull builders.
  4. PAR
    If you can draw stations, then you already are drawing sections, unless you're referring to erecting station perpendiculars (simply vertical lines). Look up "orthographic" projection to get an idea what this basic form of drafting is all about.
  5. Mr Efficiency
    The stations he referred to must be evenly spaced vertical lines, but I can understand why there is a dearth of openly available lines drawings with offsets tables, for popular modern boats, they don't want their designs being pinched !
  6. Windship277
    wow...thank you for the replies.
    What Im looking for are plans of modern Carolina style or Hatteras, Post etc sport fish and Down east boats, no sailboats yet. I have called manufacturers, expecting to get the answer i got so, no surprise there. Bruce Roberts will sell but Im not crazy about that hybrid look of traditional and modern combined.
    Yes, Im talking about simple vertical station lines. I can do a keel and bulkheads, height and width but no sections. I can get the shape needed with work and time...but Im gettin tired of that way.
  7. W9GFO
    Likes: 16, Points: 18, Legacy Rep: 39
    W9GFO Senior Member
    Have you considered 3D scanning? 123D catch, an Autodesk program, can use a series of photos to produce a 3d model.
    Once you have the 3D model you can easily slice it to get stations, waterlines and buttock lines.
  8. Windship277
    ok, might be happening. TY. Ill check it out.
  9. TANSL
    Likes: 416, Points: 93, Legacy Rep: 300
    I do not know what you call "station" but, for instance, with the same profile and the same deck, you can get infinite different hulls. So, if I understand correctly, you'll need something more to deduct the sections. If you can explain better what you have, maybe I could help.
    If I've got it all wrong, I beg your pardon.
