38 sailing hull design
Discussion in 'Boat Design' started by frank smith, Aug 6, 2010.
  1. frank smith
    Likes: 14, Points: 28, Legacy Rep: 185
    frank smith Senior Member
    This is an idea i have been kicking around , it is a radius chine sailing hull about 38' .
    Please give some advice or critique.
  2. TeddyDiver
    TeddyDiver Gollywobbler
    It's sooo double ender I don't know which way is the bow :) How's the hydrostatics?
  3. frank smith
    Yea it is , but i like them for some reason .
    Design length : 37.422
    Length over all : 37.635
    Design beam : 11.000
    Beam over all : 11.293
    Design draft : 1.750
    Midship location : 18.711
    Water density : 65.016
    Appendage coefficient : 1.0000
    Volume properties:
    Displaced volume : 274.08
    Displacement : 7.955
    Total length of submerged body : 34.237
    Total beam of submerged body : 9.889
    Block coefficient : 0.4626
    Prismatic coefficient : 0.5343
    Vert. prismatic coefficient : 0.7022
    Wetted surface area : 262.50
    Longitudinal center of buoyancy : 17.817
    Longitudinal center of buoyancy : -2.610 %
    Vertical center of buoyancy : 1.052
    Midship properties:
    Midship section area : 14.983
    Midship coefficient : 0.8658
    Waterplane properties:
    Length on waterline : 34.237
    Beam on waterline : 9.889
    Waterplane area : 223.03
    Waterplane coefficient : 0.6587
    Waterplane center of floatation : 17.881
    Entrance angle : 18.997
    Transverse moment of inertia : 1252.7
    Longitudinal moment of inertia : 12716
    Initial stability:
    Transverse metacentric height : 5.623
    Longitudinal metacentric height : 47.447
    Lateral plane:
    Lateral area : 42.236
    Longitudinal center of effort : 18.675
    Vertical center of effort : 1.051[/ATTACH]
  4. frank smith
    the bow is the front part
  5. TeddyDiver
    A bit too boxy sections for my taste and a bit high Cp.. What's the material? Steel/alloy could have some more rocker and dead rise on the bottom so the rounded chine would be easier to do. For other materials bit more roundnes.
    BR Teddy
  6. frank smith
    I was thinking ply epoxy , but the panel shape doesn't work out well.
    It is an exercise in radius chine and a barge section, the bottom would be dead flat athwart until the start of the radius , much like a junk hull ,with the idea of shallow draft , maybe twin keel arrangement .
    Frank
  7. TeddyDiver
    A bit confusing. I mean either do hard or multi chines for ply or larger round bilges for cold molded ply strips.. ?
  8. frank smith
    Right .The choice of a double ender make a constant radius difficult, but ill move it around . Of course multi chine would make it easier .
    Frank
  9. Easy Rider
    Easy Rider Senior Member
    Put a rather large wine glass keel faired in and round out the last 4-5' and it wouldn't be that much different than my Willard 30.
    Easy Rider
  10. frank smith
    BR Teddy,
    In keeping with the shallow draft , I think that keeping the Cp around .55 ,
    is sort of necessary for the stability.
    Frank
  11. frank smith
    The idea started out as a chine version of Herreshoff ' Marco Polo . Then became radius chine , and shrunk . Ah ,the dangers of a computer program.
    But I like the concept . A transom stern would make more sense , but i like the look canoe stern ,when it is right .
    Frank
  12. Eralnd44
    Likes: 2, Points: 0, Legacy Rep: -38
    Eralnd44 Wanderer
    This is simple boat. Have some of this kind in Sweden. Some are good.
  13. frank smith
    Here it is with changes . I left the lines indicating the area of radius chine .
    I am not sure if it is the right way to approach this or not .
    new Hydrostatics
    Length over all : 37.655
    Beam over all : 11.326
    Volume properties:
    Displaced volume : 236.22
    Displacement : 6.856
    Total length of submerged body : 32.169
    Total beam of submerged body : 9.531
    Block coefficient : 0.4402
    Prismatic coefficient : 0.5374
    Vert. prismatic coefficient : 0.6627
    Wetted surface area : 235.40
    Longitudinal center of buoyancy : 17.367
    Longitudinal center of buoyancy : -4.177 %
    Vertical center of buoyancy : 1.071
