351 marine engine/351 car engine
Discussion in 'Inboards' started by jrbrailsford, Jun 28, 2010.
  1. jrbrailsford
    jrbrailsford New Member
    I have a ford 351 "175" omc engine that is cracked, I was wondering if it does run opposite from a 351 car motor and if I should replace with a marine motor or can I swap parts to a car block and use that? Also, did all the 351 marine motors turn opposite?
    Thank you for all your help
    Jerry
  2. CDK
    CDK retired engineer
    To turn the other way around, the engine would need another cam and starter motor. I cannot think of a good reason to do that, but OMC might have thought different about that.
    You can acquire a car engine, look at the cams with cylinder 1 in tdc. If they look very different, use the cam shaft and starter motor from your current engine. Of course also adjust the ignition timing.
  3. Jango
    Likes: 7, Points: 0, Legacy Rep: 63
    Jango Senior Enthusiast
    Unless your OMC engine was part of a twin engine installation, where typically one runs clockwise (RH) and the second CCW (LH) as viewed from the OUTPUT, your engine is most likely a LH, the same as a car or truck. YES, the blocks are the same as the car/truck, regardless of rotation. Internals of marine engines are mostly truck parts. Camshaft could be slightly different in a truck but will work fine. Car camshafts are more "aggresive" and lack the low speed torque necessary in a boat
  4. tuantom
    Likes: 3, Points: 18, Legacy Rep: 45
    tuantom Senior Member
    I'm pretty sure you have a 302 if it's a 175. The 351w was rated at 235 Hp. If you're going by the 351 cast in the heads - both engines used 351w heads for the marine versions in Mercruisers - probably OMC too.
  5. Jango
    The 302 Intake manifold is just under 9 in. wide. 351 intakes are around 10 in. wide. My 1974, 302 Mercruiser heads have '302' cast - in under the valve covers.
  6. Fanie
    Likes: 174, Points: 63, Legacy Rep: 2484
    Fanie Fanie
    If you get the block number you may get the specifics for that engine, probably online off the internet too.
    Oh Oh Oh Oh I see it's a Ford. They don't even qualify for anchors nowadays :D
    (Ok, I'll admit, I'm a chevy fan :D)
  7. troy2000
    troy2000 Senior Member
    You obviously have no idea what you're talking about, Fanie.
    Ford engines make excellent anchors....:D
  8. jrbrailsford
    Thank you all for the advice
