Agree'd on hull shape, they will lift the lee hull as much as possible (via foils) yet retain longitudinal stability. Yes Oracle was very twisty but you have to remember the boat is just out of the box and they haven't settled/bedded the structures in yet. Probably not on full pretension yet. The AC45s used to twist horribly when new. They bed in the connections and wet set them in after they settle/stretch a bit. Plus I'm not sure what the huge rear beam is about yet. Everyone is saying its for aero lift. I havn't done any numbers to figure out how much lift it could provide, but its improbable to do this as it needs to be trimmed somehow. Plus its at the back in all that dirty air. I suspect it has some purpose yet to be disclosed. Its simplest use is a walkway. If you watched AC33 they crawled from side to side on narrow beams. This is impractical in the coming short races. Especially for the helm. Jim can run back and forth over that easily, steer anywhere as needed. So as "simple is best" I think its a runway. Peter
