32' stainless boat w/twin 400 hp
Discussion in 'Boat Design' started by gre, Sep 13, 2023.
  1. gre
    gre New Member
    Anybody have the ability to fabricate a stainless steel 32' boat.
    Greg Reader
    ARGO Sciences
    Service Disabled Veteran Owned Small Business
    772-321-3582
  2. BlueBell
    Likes: 1,267, Points: 113
    Of course. Where?
  3. bajansailor
    Likes: 1,827, Points: 113, Legacy Rep: 37
    bajansailor Marine Surveyor
    Welcome to the Forum Greg.
    Can you tell us a bit more about this 32' boat that you want to have built please, and your reasons for wanting to build it in stainless steel, rather than (say) aluminium (or steel, or fibreglass, or wood epoxy.....)
    Rumars and BlueBell like this.
  4. gonzo
    Likes: 2,295, Points: 123, Legacy Rep: 2031
    It is possible, but also a really bad idea.
  5. BlueBell
    It could be for Dubai.
    Polished SS would look pretty good with a couple of 400's hanging off the back...
    bajansailor likes this.
  6. gonzo
    Crevice corrosion is a problem with stainless steel below the waterline. It is possible to passivate it to reduce the problem. Monel would be a better alloy. However, the question is why use stainless?
  7. comfisherman
    Likes: 516, Points: 93, Legacy Rep: 10
    comfisherman Senior Member
    $$$,$$$ to burn, wheels to reinvent, buzzwords to use...so many reasons for stainless.
    BlueBell likes this.
  8. Rumars
    Likes: 1,340, Points: 113, Legacy Rep: 39
    Rumars Senior Member
    Sure, Abeking & Rasmussen and Lürssen, both have extensive experience using Nitronic 50 as a hull material. There are others that can do it, but these two are also active yacht builders for private clients.
  9. BlueBell
    "There is no correlation between brains and money."
    -author unknown
