3/8 plywood vs 1/2
Discussion in 'Boat Design' started by LastSamsara, Mar 21, 2021.
  1. LastSamsara
    LastSamsara Junior Member
    Hey, in the process of building nancys china dc15 in which the plans call for 3/8 marine plywood for the hull, with the current lumber shortages and my location I'm only able to get 1/2 inch, it only calls for 4 sheets and was just wondering if I could get away with it.. there's not a huge amount of drastic bending it seems but would the extra weight be an issue?
  2. BlueBell
    Likes: 1,267, Points: 113
    Do the plans call for good one side 3/8 or standard?
  3. LastSamsara
    They kept it simple, 3/8 marine grade plywood was all it said
  4. Russell Brown
    Likes: 190, Points: 43, Legacy Rep: 25
    Russell Brown Senior Member
    That boat would be difficult to build with 1/2" ply.
    Look for non-domestic 9mm thick ply, preferably Okoume. It doesn't pay to try to save money on plywood
  5. LastSamsara
    Fair enough, alright I'll do some more digging, just hard to believe how scarce things are now a days
  6. BlueBell
    I don't believe it's an expense issue Russell but rather a supply issue.
    We are really short on wood these days up here in the Great White North.
    LastSamsara, Yes it will make a weight issue.
    Unless you can get good both sides 1/2 that is really less than 7/16.
    OR
    Have you considered laminating door skins on the build?
  7. bajansailor
    Likes: 1,827, Points: 113, Legacy Rep: 37
    bajansailor Marine Surveyor
    Here is a link to Nancy's China on Sam Devlin's page for reference.
    Nancy’s China 15 https://devlinboat.com/nancys-china-15/
    LS, which rig are you planning on using on your boat?
    Re the 3/8" hull shell thickness, would it be feasible / practical to use two layers of 3/16" plywood (assuming that it is available)?
    BlueBell likes this.
  8. LastSamsara
    I haven't thought of that, but was playing with the idea of running the 1/2 through a thickness planer to bring it down to 3/8, I've called around and theres only one other spot I can get 3/8 and it's crazy expensive, and I'd have to pay for shipping too
  9. LastSamsara
    Was planning on going with a bermuda rig for simplicity, and I dont think so, the most standard size around seems to be 1/2
  10. BlueBell
    Is the designer available for comment?
    That would be your best bet.
    Planing 1/2 down, ugh, not an option in my book.
    I'd add (laminate) door skin to 1/4" before planing 1/2.
    bajansailor likes this.
  11. bajansailor
    If 1/4" thick plywood is available, you could maybe use this, and add an extra layer of glass cloth to compensate for the 1/8" of plywood that is 'lost'?
    kerosene and BlueBell like this.
  12. LastSamsara
    Hey might be yes, maybe that will be my next move, 1/2 seems to be all people are carrying
  13. fallguy
    Nice boat.
    Not sourcing 10 or 9 mm is a false premise.
    And a terrible way to try to build her. You will need to kerf cut the 1/2" to make it bend that much.
    Good luck.
